Rear wheel bearing replacement
Discussion in 'Generation 1 Prius Discussion' started by AlexY, Jul 27, 2014.
  1. Prodarwin
    Prodarwin Junior Member
    30
    2002 Prius
    Quick question for those that have done this: How do you disconnect the speed sensor wire? I feel like an idiot fumbling around under there and I can't clearly see how to release the clip.
  2. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    If you are talking about the rear sensor wire it just unplugs from the back of the hub unit. The front sensor has a single bolt holding it in place to remove it from the front hub carrier.
    John (Britprius)
  3. bwilson4web
    16,552
    Oh, did we mention the accumulated grit, grime, and dirt that makes figuring out where the clips are that hold the connector on?
  4. AlexY
    AlexY Member
    163
    45
    UK
    Just replaced the hub, about 30min to remove and the torch was involved, sensor plug have small clip on the top very close to the hub, under thick layer of mud, use a tiny flat screwdriver or knife to release it. Cover plate is almost disintegrated.
    BTW part ordered 7-th August, delivered 11 September, can't say I was impressed by delivery service, parcel from china came in 2 weeks...
    Whole delivery history below
    Delivered
    Sep-10-14, 19:22 PM, LICHFIELD HOME DELIVERY
    Out for Delivery
    Sep-10-14, 11:59 AM, LICHFIELD HOME DELIVERY
    Out for Delivery
    Sep-10-14, 07:30 AM, LICHFIELD HOME DELIVERY
    In Transit with Destination Carrier
    Sep-10-14, 02:02 AM, LICHFIELD SERVICE CENTRE
    Sep-10-14, 00:30 AM, LICHFIELD SERVICE CENTRE
    Sep-08-14, 18:00 PM, 13 Ten
    Shipped from Shipping Center to International Destination
    Sep-06-14, 23:46 PM, Erlanger
    Customs Documentation and Labeling
    Aug-11-14, 21:05 PM, Erlanger
    Processing at US Shipping Center
    Aug-11-14, 19:03 PM, Erlanger
    In Transit-Pre-Shipment Info Sent to USPS
    Aug-08-14, 00:00 AM
  5. ChapmanF
    19,061
    I've done it once and I'll second Bob - it's simple enough once it's clean enough and you've got a good enough angle to see how the clip goes.
    -Chap
  6. Mendel Leisk
    42,381
    What happens if you order through a Toyota dealership parts department? Price through the roof?
  7. AlexY
    AlexY Member
    163
    45
    UK
    Then I will pay over 200 instead of 70, of course if they will sell it.
  8. Prodarwin
    30
    2002 Prius
    Grrrrrrraaahhhhhhhhh
    So I got the wire disconnected, thanks for the tip above. The drum came off pretty easily. The hub... did not. I loosened the bolts and pounded on them with a punch, eventually getting the rearmost side to move a bit, but not come all the way out. I bolted the wheel back on the hub so I had a huge lever arm then just pulled it back and forth with a ton of force and was able to wiggle it out of the "knuckle" (not sure what you call that part on a beam-axle car). The problem is... the brake backing plate and all the brake goodies came with it. Now I have a loose hub + backing plate and I can't figure out how to separate :(
    I could unbolt the brake line then try and set the assembly on something and hit the back of the bearing with a sledge until it comes out. Or use a torch... and probably do the same thing? Do the Prius brakes bleed pretty easily?
  9. AlexY
    AlexY Member
    163
    45
    UK
    A torch, as I said above, about 10-15min of heating of mounting plate (LPG torch, less if you have acetylene, avoid heating of hub itself), then support the only point that can be used - pin where are 2 springs are hooked, fit screw (or 2, old ones as they will be damaged) close to this pin and "use force Luke".
  10. Mendel Leisk
    42,381
    There's no threaded holes, is there? A lot of times drums and calipers will have two M8x1.25 holes. You install compatible bolts, and then slowly starting turning them in, alternating. The pop-off can be pretty noisy.
    Probably not, but just a thought.
  11. Prodarwin
    30
    2002 Prius
    Alex, how did you support via these two pins? I'm trying to figure out how to hold it in place on one side (while the drum backing plate is scorching hot), and still be able to strike the other side.
  12. AlexY
    AlexY Member
    163
    45
    UK
    I did hold this bigger shielding plate with a hand and only one pin was supported with solid metal rod, it was badly corroded and almost fall off, heat around the hub hole, not all around.
    BTW, brake calliper was removed, don't heat if it is assembled and make sure its cylinder is blocked (use thick wrench) to avoid brake fluid leak, hand brake wire is actually safe if not heated directly, I didn't removed it.
    #32 AlexY, Sep 13, 2014
  13. ChapmanF
    19,061
    Same thing happened to me. Here's how I did it ... no sledge, no torch, no bleeding brakes ... not too bad.
    -Chap
  14. robert mencl
    robert mencl Member
    173
    49
    hartland me
    2002 Prius
    I
    ...or drive a few miles on a bumpy road with the hub bolts loosened 2 turns.
  15. AlexY
    AlexY Member
    163
    45
    UK
    Chap, our cars are 4 years older now, WD40 didn't did the job in my case.
    Robert, suppose bolts will be damaged this way, other option is put the brick under the hub and loose the jack.
  16. Mendel Leisk
    42,381
    Robert's reminded me of a similar tactic:
    When I'm swapping to snow tires, some time the wheel rim sticks, will not pull off. I leave one lug nut on at top, very loose. Then put a two by four, on edge, on the slab behind the inner tire face. Then swing a sledge hammer along the slab, into the two by four.
    Maybe similar would work with the bearing? Loosen the bearing hub nuts, put the wheel back on and tighten the lug nuts, then do the same sledge hammer bit.
  17. ChapmanF
    19,061
    This response leaves me wondering whether you read the post I linked to. I was replying to prodarwin's question about what to do when the hub is already loose but the brake plate has come with it. I suggest solving that problem in place to avoid unnecessarily disturbing the brake system. It worked for me, and my guess is it'll work 4 years later too, given that the hub is already free of the axle.
    -Chap
  18. AlexY
    AlexY Member
    163
    45
    UK
    Oh yes, main point is penetrant, I don't dispute about unnecessary disassembly, just mentioned that 4 years later in my case it not work.
  19. ChapmanF
    19,061
    I was pretty sure even in my case that the five solid minutes of slide hammering supplied more of the magic than the penetrant did. Spraying penetrant is more just the sort of purification ritual before the hunt.
    Also, for about the first four-and-a-half minutes of slide hammering there was no sign at all that anything was gonna happen....
    And my arm is not really cut out for five minutes of slide hammering.
    -Chap
  20. robert mencl
    robert mencl Member
    173
    49
    hartland me
    2002 Prius
    I
    Hub removal gone viral! But I trust Alex's responses best because his name spelled sideways is...Axle.
