Rear wheel camber adjustment on prime keeps getting off
Discussion in 'Prime Technical Discussion' started by mczouav, Sep 6, 2018.
  1. bisco
    52,878
    can you have someone videotape your confrontation with the service manager?:cool:
    52,878
    also, you would do a major service to other members in your area by naming the dealer as a warning to them.(y)
  3. mczouav
    mczouav Member
    BE
    Memphis, tn, Toyota chuck hutton...
    52,878
    wow, thanks for getting back to us!
  5. padroo
    padroo Senior Member
    2,763
    2,253
    Time for a second opinion.
  6. kimseongjae
    kimseongjae Junior Member
    40
    Los Angeles- La Canada, CA
    2020 Prius Prime
    I used to have 2005 Prius with a Scion 17 wheel. Prius with a rear axle beam does not have a camber adjustment. Only toe. If you have a premature wear on the inside of your tire, you can adjust the toe more IN to reduce inside tire wear.
  7. Mendel Leisk
    42,364
    You're saying 3rd gen style solid rear axle you can adjust toe? I can't see that. The operative word being solid.
  8. kimseongjae
    40
    2020 Prius Prime
    Sorry. LOL. I got it mixed up with a Lexus I had some time ago. you are correct. there is no toe adjustment. I'll take it down. Thx. for the correction. Don't want to put out wrong info. here.
  9. Mendel Leisk
    42,364
    No worries. I think barring the use of shim, there's squat you can do with the 2nd/3rd gen.
    However, and I missed it completely: OP has a Prime (4th gen with extra electrons), with the independent rear suspension. Not sure what's adjustable, but it certainly doesn't have the restrictions of previous Prius gen's.
  10. Shaunius
    Shaunius Junior Member
    91
    24
    City of Angeles
    I own two primes; one my wife’s and one mine 20 prime XLE on Bridgestones and it’s always been a bit more squirmy than my wife’s 19 Toyo LE has been rock stable the dealership is staying -2.1 rear camber is normal?
