rear wheel slanted
Discussion in 'Prius c Main Forum' started by mmc99, Feb 24, 2024.
  1. mmc99
    mmc99 New Member
    Noticed my rear wheel is leaning, i removed the wheel nothing seems loose. Any help much appreciated. I know my daughter hit a pot hole, ugh
  2. Tideland Prius
    16,683
    You'll have to take it into a shop (dealer, or tire shop or bodyshop. Basically anyone that has the tools to do wheel alignments) and get that wheel aligned. The sooner the better (so that you don't excessively wear out the tyre).
  3. BiomedO1
    BiomedO1 Senior Member
    4,632
    2,430
    Left Coast
    There's been reports of weak/broken weld joints in the rear sub-frame assembly, between where the tire mounts and the uni-body frame itself. Do a search on Prius C rear wheel alignment.
    Hope this helps...
    John in Vermont likes this.
  4. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    I think you're allowed to call them 'craters' when they can do that to your car.
    Good luck!
    Tideland Prius likes this.
  5. ChapmanF
    19,041
    I think the scale as I learned it was potholes, chuckholes, Sir Charles Holes.
  6. Mendel Leisk
    42,358
    #6 Mendel Leisk, Feb 24, 2024
    BiomedO1 and Tideland Prius like this.
  7. BiomedO1
    4,632
    2,430
    Left Coast
    NICE!!!
    A more affordable option, if you find broken wield joints is a junk yard. The Yaris and Lexus CT200 uses the same sub-frame assembly. Please double check and cross reference; in-case I'm wrong or it doesn't cover your model year. Toyota does make mid-year changes.
    Good Luck...
  8. 2013 PRIUS C VINNY
    2013 PRIUS C VINNY New Member
    poconos
    I have a 2013 and what i thought was a bad wheel brg. wound up being the axle is cracked. The left rear wheel was rubbing on the shock. same thing when i took it apart everything looked tight. then i took a tire iron and put it through the hole in the hub next to the
    lugs and pushed it up and down.
