Rear wheel speed sensor replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NicoB, Jun 24, 2026.
  1. NicoB
    NicoB New Member
    Erie County, PA
    This topic is most likely already posted. If so, please redirect me.
    I have Code C0210 indicating failure of the right rear wheel speed sensor. The bearing is fine, so I don't really need to replace the whole wheel bearing & hub assembly... just the wheel speed sensor. I can't seem to source the sensor only for the 2010-2015 gen vehicle, but I can for the prior gen on PartsGeek and Amazon, and it seems like the same part, Will this part fit on my 2010 model?
    Thanks!
    Screen Shot 2026-06-24 at 5.05.02 PM.png Screen Shot 2026-06-24 at 5.06.54 PM.png
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,152
    6,992
    Texas Hill Country
    You have to replace the whole hub
    This is the part number for my Prius v
  3. NicoB
    NicoB New Member
    Erie County, PA
    Thanks. OEM & Timkin are a bit over my budget. Do you know anything about the quality of Detroit Axle parts?
  4. rjparker
    11,152
    6,992
    Texas Hill Country
    Lots of the aftermarket hubs only last a couple of years.
    Its a gamble.
  5. cdherman
    cdherman Member
    68
    27
    Kansas City
    Agree with RJParker. You gets what you pays for, at least in this instance.......
  6. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    They are junk.
    Moog worked good for me. Just make sure you get the ones made in AMERICA.
    Other country ones are junk. They was an article I read a few years ago I wished I had saved
    that did quality tests from the different country they are made in and the USA ones were much
    better quality.
