Rear Window Defogger in 2010 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Palladin, Jan 1, 2019.
  1. Palladin
    Palladin Junior Member
    Southern Maryland
    The rear window defogger in my 2010 Prius doesn't appear to be working. Naturally, the first thing I want to check is the fuse. I can't find any mention of it in the manual and every link I find takes me to a resolution for a pre-2010 Prius. Can anyone tell me where the fuse is located or how to search the gazillion post threads for the answer?
  2. ashton.agar
    ashton.agar New Member
    New york
    2011 Aqua
    I did communicate with Toyota, but they were not much help. However a technician who post's here on PC did provide the correct information.
    Please refer for a good support.
  3. ChapmanF
    15,649
    There are labels in the fuse box covers, and I think even a page in the owners' manual reproducing them, but they are also sort of like the labels in your Grandpa's fuse box: terse, and giving no hint of half the things actually on the circuit. Even though it's some extra trouble to check the wiring diagram, it pays off, because it always shows exactly what's where.
    Even so, I've got to caution about the seemingly universal instinct to look for a blown fuse. If you find one and replace it, you haven't fixed your problem; you've learned that your problem is to work out why the fuse blew.
  4. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Make sure connectors are securely attached
