Rear Window dirt magnet
Discussion in 'Prius v Accessories and Modifications' started by jim1, Jan 14, 2014.
  1. jim1
    jim1 Junior Member
    Montreal, Quebec
    2013 Prius v wagon
    Did the Prius v not pass wind tunnel tests? The rear window collects dirt instantly and needs continual cleaning/washer-wiper action. Are there any spoiler mods or other workarounds for this?
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Pretty much any similarly shaped vehicle will do the same thing. The aerodynamics that cause this are the same ones that give you good MPG. The fix is a garden hose.
  3. orenji
    orenji Senior Member
    5,887
    3,488
    U could always drive backwards! ;)
  4. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    I don't think the Tesla has this issue and it has virtually the same coefficient of drag (.25)
  5. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Which is not in any way relevant to the Prius-v wagon's body style.
    kithmo likes this.
  6. Zrkia
    Zrkia Junior Member
    17
    Michigan
    Any vehicle with a squared-off rear creates a vacuum as it moves through the air, sucking the dirt onto the rear surface. That is why almost all wagons and SUVs have rear window wipers. The rear of a sedan also gets dirty, but the rear window is farther forward, so it doesn't get dirty.
  7. mikefocke
    4,046
    1,840
    Sanford, NC
    All of us experience the same thing with the v. I carry old towels and wipe it off when I see it bad and it is still wet. Or wait till I get home and use the hose like I did today. Do you also pick up dirt around the edges of the doors? I do.
    No car is perfect.
