rear windows roll down not completely and evenly?
Discussion in 'Gen 4 Prius Main Forum' started by randomwalk101, Apr 30, 2016.
  1. randomwalk101
    randomwalk101 DYI'er
    532
    268
    texas
    So I have never rolled down the rear window to noticed until now. I was messing around with TechStream's option (turning on the pressing the remote unlock button 2.5 seconds to roll down all windows).
    Anyways, it worked but when I looked at the rear windows, it doesn't roll down 100% like the front. There is about 1" left towards the front edge of the rear door left when it bottoms out. Also the left side (driver side) is bottoming out slidely higher than the rear passenger side (may be about 1/4" higher). Is this normal?
  2. Montgomery
    Montgomery Senior Member
    2,254
    2,234
    Orange County, CA
    Is this a new 2016 prius? For my 2015, both rear windows roll all the way down and evenly.
  3. randomwalk101
    532
    268
    texas
    Yes. 2016 /gen 4 Prius. Sorry I didn't mention that since this is a gen 4 section
  4. Montgomery
    2,254
    2,234
    Orange County, CA
    I would take car to dealer and see if other new ones do the same thing
  5. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    I think this is normal. In almost every car I've had for the past 20 years, I've had the rear windows have a little bit of window showing when fully rolled down. I think this is a child safety feature so it isn't as easy to fall out of the windows.:eek: It happens on mine and my old Prius
  6. randomwalk101
    532
    268
    texas
    Ummm I wouldn't go that far... But if I'm a kid falling out, I would definitely hang on that 1" window ledge...Lol
  7. 'LectroFuel
    880
    673
    Some cars show more of the rear windows, like my 2005 Prius. I might also have to do with the shape of the door. The window might not have enough room to roll down completely.
  8. randomwalk101
    532
    268
    texas
    Actually I was hoping someone with a 2016 just roll down the rear windows and see if it looks like that. That would save me a trip to the dealer if that is the way it's designed.
    Since the two sides are the same (but with the passenger side coming down just a tad lower), I'm thinking that's the way it is but don't mind confirmation :)
    #8 randomwalk101, Apr 30, 2016
  9. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The GII Prius is the same. It's because the door is shaped to fit around the wheel. That means there isn't enough room for the glass to roll all the way down. Many cars are like this. I haven't tried in my GIII (it's hard to drive it from the back seat) but my guess is it's the same with it as well.
    It has nothing to do with child safety. Rear door child safety locks are the little toggles on the inside of the door frame (open the rear door and you will see them). With those engaged the rear doors can only be opened from the outside.
  10. alanclarkeau
    alanclarkeau Senior Member
    7,041
    7,580
    near Brisbane, Australia
    This is my FORD, and my last few cars at least have been much the same. I think it could be the profile of the roofline, the profile of the top of the door, and that the glass can't drop too deep inside the door. The door also narrows toward the bottom. 20160501_124657_resized_1.jpg
  11. Kenny94945
    Kenny94945 Active Member
    769
    394
    Sausalito
    2016 Prius v wagon
    The OP asked if someone can roll down their rear windows and see if the windows go flush.
    Else he can travel to his dealer which, OP, may be the quickest answer.... plus free coffee there?
    That's the way I read the post.
    I have a 16 prius v...not applicable.
    Good luck.
  12. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Here are my 2016 trim 4 rear windows.
    A little does stick out.
    Hope this helps.
    jp
  13. randomwalk101
    532
    268
    texas
    Thanks JP.
    Actually my name is also JP (Jean-Pierre)
    May be I should change my nick to "I'mJPtoo". Lol
    'LectroFuel likes this.
