Rear wiper
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by tgpii, Dec 20, 2017.
  1. tgpii
    tgpii Member
    382
    63
    Tapier Lake/Orland Park, Ilinois
    I have a 2012 Prius C. I had it since new. It seems the rear wiper blade tends to wear out unusually fast. If I replace the front and the back at the same time, the back one goes out fast, like in a month or two and the front are fine. Maybe I should not turn the back one on unless it is pouring rain, or a blizzard? I think part of the issue is the front window is raked and the rear window is straight.
    Anyways, is this a common issue?
    Do they make an extra heavy duty maybe aftermarket rear wiper blade? Something with better rubber then OEM? Do you think it would be worth it?
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Only for those that USE the rear wiper. :D
    How often do you manually CLEAN the gunk off the rear blade ?
    Do you tend to run it when there might be more grime on the window than actual moisture ??
    I don't think there are many choices for that size blade.
    The one on my first C lasted 3 years.......but I used it infrequently.
    P.S. I assume that the spring tension holding the blade to the glass seems OK ??
  3. Kenny94945
    Kenny94945 Active Member
    784
    400
    Sausalito
    2016 Prius v wagon
    I think Sam above sums it up.
    What is speeding up the wear of the rubber?
    Grit buildup, using on a dry glass, heat.
    Maybe do some preventative maintenance/ cleaning on that rear blade and glass?
  4. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    I've just now changed my rear wiper blade at 85k miles... but it needed it at probably 65k miles. I just didn't need it as much as the fronts. I have swapped the fronts out at 85k miles too. They were slightly streaky, but for the most part still good. I did notice a difference, but I'm not sure if it was from cleaning the windshield or changing the wipers. :D
  5. wigmann
    wigmann Junior Member
    42
    Deerfield Beach FL
    2015 Prius c
    all of my wiper blades made it about a year and a half. all seemed to wear out at the same time. I do clean my blades of occasionally and use a rubber cleaner on them. they were all changed at about 20k miles.
  6. tgpii
    tgpii Member
    382
    63
    The front wipers that are used more seem to last longer.
  7. Reid_in_QC
    Reid_in_QC Junior Member
    les Cèdres, QC
    I agree with the premature rear wiper wear assessment but I drive dirt roads and in winter road salt here in rural Canada so I'm not overly shocked. My rear blade tears off at tips, losing about 1.5cm from either end in about 8-12 months. It wouldn't matter as much on a 20" or 28" wiper but on a tiny 8" blade any reduction is unwelcome.
    I'm going to order a Bosch rear wiper (Bosch model H240) and hope it clears. 8" original is H200 but there's honestly room for a bit more and every little bit helps when peering through the aft portal. I can confirm that an 11" definitely doesn't fit (tried it) but I'm confident that 9" will and 10" might even fit (H252) though I'm not going to risk it on special order item.
    I'll post confirmation once it's fitted.
    2012 Prius C (with roofracks!)
  8. Leadfoot J. McCoalroller
    7,176
    6,722
    Pennsylvania
    2018 Prius c
    Awesome info! That rear wiper is already at a disadvantage given that it is mounted/angled best for RHD cars, no LHD version for North America. They were hoping we wouldn't notice.
    240mm works out to 9.44" so I think you've got a shot at a good fit.
  9. Reid_in_QC
    les Cèdres, QC
    My Bosch wiper arrived and unfortunately it's not a direct snap-in replacement. I did get it to work and it's a big improvement over the previous 8" but I can't say I'd recommend it to everyone. The mounting/pivot pin is smaller diameter so I made a kind of "cylindrical shim" from a short length of split and emptied electrical wire insulation. Also the tip of the blade's plastic body didn't quite clear the plastic surround at the top of the rear window but with a little belt-sander sculpting i managed to gain a couple mm and now it clears, if only barely.
    In conclusion, don't go with the Bosch H240 as a direct fit but if others want to keep looking for alternatives the lousy little 8" from Toyota/Trico maybe try for a 220 or 230mm blade that's got the same mount style as used by Toyota. When you find it please tell us all.
  10. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Isn't our factory rear wiper a 5"?
  11. Reid_in_QC
    les Cèdres, QC
    The factory rear wiper is nominal 8" - like having a toddler swipe the rear glass with a mitten. Here in Canada there seems to be only one aftermarket option: Trico model TRI2383520. This may be exactly the same thing Toyota sells as OEM part. They're about $15 online but do nothing to improve over the original.
    Update on my Bosch H240 trial is that it failed prematurely due to my efforts at thinning the mount section to make it fit the Toyota wiper arm. The thinned section broke in use and the wiper ended up in a ditch. However, having had a month or two with a working 240mm wiper and the resultant great rearward visibility I'm loathe to go back to the Toyota spec'd 8" so I'm still looking for a 9" or 230mm with the correct mount. For now I've just strapped a toddler with a wet mitten to rear of the car.
    I learned that the mounting style is called Roc Loc 2 and was developed by Denso, I think. If anyone can find a 9", 220mm or 230mm wiper with Roc Loc 2 mounting we might have a winner. I'll let you know if I find anything.
  12. skayaks
    skayaks Active Member
    123
    107
    Massachusetts
    About a year ago I addressed my rear wiper fix in another thread:
    Rear Wiper Fix | Page 2 | PriusChat
    By my ruler the modified blade is 9 ¾” (24.8cm) vs. the stock blade at 7.6” (19.3cm)
    That blade is still available at love-it-or-hate-it online, and after a year I still consider this a fix worth trying if you dislike the foolish stock wiper.
    I carried the old blade around for a while in case my fix went south, but the improvement is good enough that I plan to buy a replacement of the Trico blade and repeat the modification when it's replacement time.
    #12 skayaks, Mar 11, 2019
