Rearview mirror
Discussion in 'Prime Main Forum (2017-2022)' started by HPrimeAdvanced, Nov 2, 2017.
  1. alexcue
    alexcue Active Member
    346
    311
    So Cal
    Mine works fine, no issues and no tinting. I do notice a difference, as I hated flipping the switch on my Gen 3.
    The GF's Chevy Bolt has an actual rear view camera view when you flip the switch! Now that is cool!
    HPrimeAdvanced likes this.
  2. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    As I stated in follow-up post, the mirror dimming does work; it's just not sufficient for me and I'd like to be able to adjust it.
  3. Tideland Prius
    16,658
    Might explain why in Canada, they left out the auto-dimming mirror except on the top spec package. (all models have manual day/night mirror as standard)
    Prodigyplace and HPrimeAdvanced like this.
  4. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    You gotta hope the engineers provided some way to program or alter the level of darkening provided by the mirror!!. My very bright flashlight made the mirror nearly "black"; lights from traffic, on the other hand barely had any/enough effect. If that mirror is as expensive as I've heard, it hadda oughta better dad nab have some kinda flippin' adjustability, or "Compliance Control"!!
  5. Tideland Prius
    16,658
    Yes that's how it's supposed to work (because you're shining a light into the light sensor which dims the mirror). Again, if you can find a way to expose the light sensor such that the headlights behind can reach it better, that will help solve your problem.
  6. Prodigyplace
    12,708
    11,847
    Central Virginia
    Do you think a Gen 4 Prius mirror would fit the Prime? Mine is manually controlled. Perhaps @HPrimeAdvanced could buy the OEM part.
  7. Tideland Prius
    16,658
    They *should* be the same.
  8. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    The thing is, that I want to keep the mirror's remote garage door openers feature, while improving the performance of the mirror's dimming feature. Marie Antoinette said I could have it!! Stubborn gets!!
    Tideland Prius likes this.
  9. Prodigyplace
    12,708
    11,847
    Central Virginia
    She only has influence in France. :rolleyes:
  10. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    I, unfortunately, believe it is, "had influence", since her "head" has somehow been "misplaced"!
    From Little Anthony and the Imperials, "Well I think I'm going out of my head...!" But I digress..., har, har, !!
  11. Prodigyplace
    12,708
    11,847
    Central Virginia
    I believe you have misplaced your country too, so I thought you would not catch that detail, mon ami.
  12. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    At times I have noticed significant dimming, and at other times have thought it should dim more. Since driving at night is rare for me, not much effort to improve the situation has been tried. At one time I thought turning the MFD off and dimming the dash lights helped, but a recent experience questions this approach. In my gen 2 Prius turning the mirror upside down improved the dimming. My Prius Plug-in was base model with manual flip.
