Featured Reasons behind the slowness of EVs adoption in US
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by KrPtNk, Mar 11, 2019.
  1. markabele
    5,084
    1,782
    Nebraska
    LOL
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Wikipedia says this about minivans:
    "The minivan combines a high-roof, five-door one- or two-box hatchback body configuration with a mid-size platform, engine and mechanicals; car-like handling and fuel economy; unibody construction; front-wheel or all-wheel drive and greater height than sedan or station wagon counterparts.
    The Mazda5 has five doors (two sliding) in a hatchback configuration on a compact platform (yet, it's classed as a mid-size vehicle) with car-like handling and fuel economy, unibody construction and front-wheel drive. It's taller than my Prime by 6 inches.
    It also says the first real minivan was the 1984 Dodge Caravan, which had a wheelbase of 2,847mm and was available with a 2.2L or 2.5L I4. The Mazda5 has a wheelbase of 2,750mm and has a 2.5L I4.
    So, it's only 3.8 inches shorter in wheelbase than the first true minivan.
    Autotrader calls it a minivan: Autotrader - page unavailable
    It's got all the characteristics of a minivan - sliding doors, three rows, car-like performance, higher roof than a sedan. It's just a small minivan, rather than a humongous minivan like a Sienna.
  3. hill
    8,806
    50 yes - 30 no ..... but our first Tesla had both,
    as well as others. that's pretty cool - camping in a Tesla, as you have Shore power at campgrounds. Either heat or AC all night. I still recall when they added the camping mode over the air update, which allowed you to have your car off but 120v receptacle / heating / AC still working.
    #283 hill, Mar 27, 2019
    Zythryn likes this.
  4. 3PriusMike
    3,100
    2,419
    Silicon Valley
    So let me understand. You are suggesting that people (mass market) will get a PHEV and desire opportunistic fast charging up to 19.2kw at home in order to save money on time-of-use rates? At 240 volts, the max most homes can support, that would be 80 amps. How much do you think it would cost to install this and buy the EVSE? Especially in a home that has only 100 amp service.
    How often would you need to use this in order to break even compared to a 40amp device...saving maybe an extra 10 or 15 miles of EV range per use?
    How many PHEVs do you think are going to support 19.2kw charging?
    Mike
    Trollbait likes this.
  5. hill
    8,806
    iirc i3 (bob can correct) has the highest charge rate, 10kW? Volt - out of production moved up to 7.2kW. And several other manufacturers have now moved up to 6.6 ..... so it's kind of dependent on how big the pack is, as manufacturers fear charging reasonably fast, even though they obviously have to discharge with some degree of speed - even more than changing. When a phev charges AND discharges faster, that's 2 sources of heat creation, which, unless it's liquid cooled, is going to work against longevity. Then, liquid cooling increases manufacturers cost, so, decisions get made to keep 'em cheap & let the capacity loss cards land where ever they land.
    #285 hill, Mar 27, 2019
  6. bisco
    51,946
    rid of what?(n)
  7. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    No, I'm just pointing out the range of opportunity available. Likely, only a small number will actually do that. Awareness helps adoption.
  8. bwilson4web
    16,217
    Calm my friends. Early adopters of the Gen-1 Prius had lessons to learn and as a buyer of a Gen-1 in 2005, I did too.
    I can’t fix the ignorance of others ... just my own. I share my lessons learned but have no expectations that others will gain insights from my posts. Just sharing facts and data.
    I crossed “the great divide” with my ability to handle the challenges. If others choose a different path, go with no criticism by me. GOOD LUCK.
    Tideland Prius, Zythryn and markabele like this.
  9. Lee Jay
    5,850
    4,036
  10. Trollbait
    12,542
    It isn't a problem, it's an option for those in which the Supercharger network isn't enough. Considering the fastest CHAdeMO out on the street aren't even half the rate of a Supercharger, this just stop gap solution until more Superchargers come online.
    Without this adapter, Tesla's still can use Level 2 public chargers if needed. Which is the only option other BEVs have when the available DC charger isn't their standard.
    Then considering the cost increase of having both CCS and CHAdeMO on a charger is tiny, there not being a charger in first place is the more common issue. An issue that only applies for those using BEVs for long trips.
    The availability of this adapter would like getting the ability to burn diesel in a gasoline car.
  11. bisco
    51,946
    if it's a problem for you, it's a problem :cool:
  12. Lee Jay
    5,850
    4,036
    No, it's a problem.
    If *any* adapters exist, it means there are multiple standards, and that means difficulty for consumers.
    USB-A, USB-mini, USB-micro, Thuderbolt, and USB-C are an example. It's taken until about now to finally get some convergence toward USB-C replacing everything - USB-micro, Thunderbolt, mini-DisplayPort, DisplayPort, and all the power connectors.
    Imagine if different houses in the US had different wall outlets and different appliances supported different wall outlet standards. You'd need to have adapters handy to deal with the fact that your vacuum or computer power adapter doesn't plug into your wall outlet. Annoying.
    Maybe Tesla will abandon their plug and switch to CCS worldwide, leading to the demise of CHAdeMO and J-1772 (only) over time. Seems like that's happening in Europe.
  13. hill
    8,806
    not that adapters aren’t anything more than a red herring, CHAdeMO is the default adapter in Japan so no, it won't disappear.
    CCS in Europe is way more common than CHAdeMO - so naturally Tesla would come up with an adapter that works on that format. Hard to say how standard it is though, as the UK iirc is running 50 hertz? Similarly not positive about all the varying EU countries. But in the realm of dissimilar formats, there you go, even delivery of electricity is all over the board. Japan is the worst example, being different voltages and whatnot from one Province to another.
    for some - it's a problem, even though it doesn't apply to them, because they aren't even a user, much less the one percenters.
    #293 hill, Mar 28, 2019
    Trollbait, iplug and austingreen like this.
  14. Lee Jay
    5,850
    4,036
  15. Tideland Prius
    16,559
    And don’t Teslas in China have both the Tesla porker and the Chinese standard port?
    hill likes this.
  16. Lee Jay
    5,850
    4,036
    This is one of many reasons I'm not a user. This type of thing turns off consumers, and isn't that the sort of thing this thread is about, exactly?
  17. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    I agree that differing standards are a negative for some consumers. But it certainly isn't the catastrophe you make it out to be.
    EVs are penetrating the market at incredible speeds, worldwide, considering the magnitude of change they require.
    And while you may have your own reasons for not adopting a BEV, many others find those issues either unimportant or minor compared to all the advantages.
    You seem to be grasping at straws though. For your own sake, I would suggest you learn more, and speak more carefully. Hearing a news piece about DC adapters and translating that into Tesla not offering a free adapter for the 2nd level chargers is how one gets a reputation for spreading FUD.
    #297 Zythryn, Mar 28, 2019
    Trollbait, 3PriusMike and markabele like this.
  18. hill
    8,806
    building 5000-7000 plugins a week - apparently it's not enough turned off users to amount to a hill of beans. Just the one percenters. It's a good thing 1% are turned off, because they can only build them so fast ..... don't need the customer lines to be any longer than they already are
  19. Lee Jay
    5,850
    4,036
    I think you two just aren't paying attention.
    EVs are 2% of the market or so. So, the "1% [who] are turned off" looks more like 98% to me.
    Trust me, if EVs were superior, they'd be 80-90% of the market in no-time (and from all manufacturers), just like how digital cameras demolished film cameras in just a few years.
  20. markabele
    5,084
    1,782
    Nebraska
    OMG....this guy (palm to face)
    Trollbait, bisco and Zythryn like this.
