Reasons NOT to buy a PIP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Oskar, Sep 4, 2015.
  1. Oskar
    Oskar Member
    249
    96
    Massachusetts
    2020 Prius Prime
    I've owned by 2014 Prius for a year now, but have slowly been intrigued by the PIP. I get such great mileage out of the hatchback (@60MPG) that I'm thinking I could do way better with the PIP.
    But I'm wondering what the "down" sides are to a PIP. Does it require more attention or maintenance than a hatchback. Is it more expensive, or more difficult to maintain, etc?
    Chances are I probably won't go for one, but..... at any given point I might just decide to pursue it. Any comments would be most appreciated. Thanks.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    More expensive.
    Needs electrical work at your home to charge at home.
    Needs electrical work at your employer to charge at work, and an employer willing to do so.
    'Refueling' is now an everyday chore to remember.
    Not available in every state, so mechanics will not be familiar with it in every state.
    There will not be a 2016 Prius PHV.
    Much shorter electrical range than Volt, Leaf, or Tesla.
  3. mrbigh
    3,686
    699
    Long Island, NY
    As my experience for the last 3 1/2 years, no extra maintenance was required than oil changes.
  4. Xterra72
    Xterra72 Senior Member
    1,437
    1,684
    Tied down to an outlet.
  5. bisco
    52,858
    after two lift backs, the pip is a refreshing surprise in motive power and operation.
    i have loved every minute of my 3 1/2 years and 33,000 miles. i cannot think of one reason not to buy one. it does not have a spare, so i keep one in the hatch. that is not a reason to stay with the lift back imo.
    i think my favorite part (small things are sometimes the best) is when you start up, the engine doesn't start up until you want it to.
    i will say, after 15 miles of ev, it leaves you craving more.:cool:
    Alfonso1970 likes this.
  6. mrbigh
    3,686
    699
    Long Island, NY
    (y)
  7. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    The PIP only requires a 120v socket so no additional electrical work is needed. 240v is an option not a requirement. Plugging in is no more a chore than plugging in one's phone. It's such a trivial matter, I frequently don't even remember that I plugged in. A quick check on my phone app verifies that I did.
  8. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Regular Gen IV!
    Calculated cost to drive 25 miles in a 50 mpg Prius. The cost is even lower if more than 50mpg, $2.00 a gal/12 cents electricity looks like this! Compare Side-by-Side
    #8 Sergiospl, Sep 4, 2015
  9. Trollbait
    12,830
    With the ICE and slightly better fuel efficiency than the liftback, I'd don't see how that is so.
  10. Fore
    Fore Don't look back!
    494
    107
    Fast Depreciation!
  11. Xterra72
    1,437
    1,684
    One reason I did not go with a PIP. Maybe someday but not now. Especially with a 100 mile round trip commute, the last thing I need is trying to figure out how to get to a charging station. Also don't like the idea of having it charge while I have it parked outside.
    Just my preference.
    #11 Xterra72, Sep 4, 2015
  12. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Yikes you may want to jump as PiP1 is out of production, and I think MA may have decent rebate. But the downsides would be little less storage, no spare tire, and I now forget the third minor disadv. As you live in MA you get 150k mile CARB warranty helps. No one has reported much maintenance cost or batt issues of major nature. Gaso price headed lower so your elec saving is not that good in MA. IN some favorable cases the bigger batt helps to get more regen miles, but your needs may not allow getting too much more out of it than just the plug-in ability to buy elec rather than gaso.
    I like PiP maybe PiP2 with the induction charging sounds fun.
  13. twocell
    twocell Junior Member
    East
    I would love one.
  14. mrbigh
    3,686
    699
    Long Island, NY
    In certain circumstances, Induction Charging is NOT such an advantage.
    Besides, it is about an 80% efficiency......:eek:
  15. Oskar
    Oskar Member
    249
    96
    Massachusetts
    2020 Prius Prime
    Here's what I don't understand. Do you have to plug in the PIP every day? Does it regenerate the battery like the hatchback? Can you drive it like a hatchback, or is the PIP fully dependent on plugging it in at certain points. What happens if you don't plug it in and the battery goes to zero,can it be recharged by just driving/braking the PIP? I assume it's exactly like the hatchback, but offers the option of a plug in system that can allow you to get better mileage. What am not getting here?
  16. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    The few commercials Toyota did produce for the PiP , they went out of their way to communicate that it was indeed a Plug In PRIUS, which means you can drive it EXACTLY like a regular hybrid if you wish, the plug in is optional. However...
    The benefits produced by plugging it in and getting X amount of EV range, I don't know why anyone would buy one and use it ONLY as a regular hybrid. I'd charge and use EV as much as possible.- But you don't have to.
    Somebody correct me if I'm wrong, and I might be, but I also seem to remember some exclamation that the Electric Motors in the Plug In Prius were built to slightly heavier duty specs. Electric motor bushings if I remember right.
  17. fotomoto
    5,639
    3,815
    So. Texas
    No, charging isn't required and the car will behave like a regular Prius. It can and will regenerate WAY more than a hybrid because the battery is larger (you could conceivably fill it up with a long enough down hill road).
    Many folks have said they only bought them to get HOV access and never charge them.
  18. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    I have the idea to make that a solar recharger (not sure if it is possible)
    Data Daedalus likes this.
  19. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    It's a plug-in-lite and you don't have to plug in. The worse case scenario for you is depending on you routes it may or may not give you much better than regular Prius. But sounds like you drive with regen in mind so maybe you would benefit (not saying it's worth it $$).
    #19 wjtracy, Sep 4, 2015
  20. PeteSJCA
    PeteSJCA 2013 Prius Plug-In Base in Winter Gray
    73
    san jose
    2013 Prius Plug-in
    My 2006 Prius, over the six years+ that i had it, averaged 50-51 MPG over it's lifetime with me. I now have a 2013 PIP, and I love it. My round trip commute is about 35 miles, and I generally plug it in at night when it's in the garage. My average MPG over the past two years is around 80. That's not bad. I just bought a JuiceBox level 2 charger, and it now takes only about an hour and 15 minutes for a full charge, great for weekends when I may charge it a couple times a day.
