Reasons NOT to buy a PIP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Oskar, Sep 4, 2015.
  1. el Crucero
    el Crucero Senior Member
    1,628
    699
    Inland Empire
    Yes, does your ICE automatically come on when you run out of EV miles? Mine doesn't if I stay within the parameters of battery power as a hybrid.
  2. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    I thought the parameters of battery powered only for the hatchback or EV range depleted PiP was under 25MPH (or some low speed) and just over 1 mile (without AC). Then the ICE has to turn on to move the Prius and charge up the traction battery to keep it in the happy middle %60 of capacity.
  3. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    That's EV mode only, which utilizes more power. Regular electric-only in HV mode doesn't. It draws less and had an upper threshold of 46 MPH.
  4. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    How does electric only in HV mode draw less than EV mode to move the same vehicle?
    How fast and far can you get in electric only HV mode at 40 - 46 MPH on level surface on that smaller hatchback traction battery or the PiP HV mode traction battery reservoir?
    I love to learn about the Prius. Thanks.
  5. john1701a
    12,818
    5,303
    58
    It takes less power to sustain a cruise than it does to climb a hill, even though the cruise can be much faster. There a counter-intuitive nature to how some things actually work.
  6. bisco
    51,939
    when i run out of ev power, i can go a mile or so on flat ground, before the ice kicks in to recharge.
  7. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    So less power to sustain a cruise, but ICE power to get up to cruising speeds?
    I have come to understand how working against gravity on a hill takes more energy than working against air resistance and friction while sustaining a cruise with the help of Prius gauges.
    I'm just trying to understand the 15 miles of battery only HV mode that el Crucero reports. I have to believe that there is a lot of ICE support in those 15 miles of battery only HV mode driving after EV miles are depleted.
  8. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Sorry, that is not clear at all.
    Are you saying you can drive extra 15-17 miles on battery only in HV mode?
    On flat surface, mine (and others') can drive only 1 extra mile this way, maybe a bit more being extra careful, before the ICE is joining to charge battery.
    Can you please clarify?
  9. john1701a
    12,818
    5,303
    58
    PLUG-IN HYBRID means a significant MPG boost (and emission reduction) from plugging in.
    It will take advantage of the engine, rather than sacrificing electric for the sake of keeping it off. The goal is balance.
  10. bisco
    51,939
    yes, me too.:)
  11. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Another mystery!
    My ICE is coming on automatically in those circumstances for the warm-up cycle. I believe yours is doing the same.
  12. el Crucero
    1,628
    699
    Inland Empire
    I don't what to say other than that has not been my experience under the conditions I drive.
  13. bisco
    51,939
    c'mon, you modded something! share!:p
  14. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    I believe you are correct, or that the portion of the trip that EV mode was utilized was downhill.
    Yesterday my electric range showed 16.5 miles after completing the charge cycle. That's because I switch to EV mode anytime the power requirements to maintain speed are low (downhill, slow speeds, etc).
    It's most efficient to have the gas engine do the hard work, and the electric motor do the easy work. Gas engines are much less efficient at producing low amounts of power.
  15. bisco
    51,939
    maybe so, but that will lower your mpg's.
  16. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    No free lunch...
  17. PoPoPlatter
    PoPoPlatter Junior Member
    30
    Angeles Jungle
    Just to clarify, this can ONLY be done with a PiP, and not a regular Prius.
  18. el Crucero
    1,628
    699
    Inland Empire
    Could it be the bicycle pedals, chain, and sprocket to the front wheels? :whistle:
  19. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    No.
    When PiP EV miles are depleted it behaves exactly the same as would a regular Prius with 6 bars on the battery icon and cold ICE.
  20. el Crucero
    1,628
    699
    Inland Empire
    Yes, with a PIP and then not under all conditions as you have seen from the replies. It is hypermiling taken to the extreme; most people don't have the patience or right conditions.
