REBOOTING
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Andyprius1, Mar 29, 2013.
  1. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    An interesting thing happened at the gym today. While getting my 15 ft extension out at the Gym I apparently hit my reboot switch. Coming back out I unplugged and started, only to find out I had no power. Right away I knew what had happened, so I crawled back there and hit the switch up again. To my surprise, I now had a 14 mile range as compared to the usual 10.8. Apparently the traction battery liked sitting in the warm sun today. To reboot or not, that is the dilemma. There are many naysayers to this procedure, but I say they really have not tried it. I call them doubting Thomases. Cheers.
    52,747
    i may give it a try, it would be worth it if i could get to work and home without having to plug in at work!
  3. Andyprius1
    2,327
    859
    Cool CA
    Great I installed a permanent toggle switch to the neg lead. More naysayers will warn you of power surges. In the 7 years with my 2005 I never experienced a power surge thru my toggle switch. More theoretical nonsense.
    52,747
    the switch is certainly worthwhile if it increases ev miles, you want to do it every day i would imagine. what specs does it need to have?
  5. CharlesH
    2,798
    1,166
    Roseville, CA
    I am confused. Why would one care what the displayed estimated EV range is?:confused:
  6. bisco
    52,747
    those of us who understand the system wouldn't, but we're talking real miles here!
  7. Andyprius1
    2,327
    859
    Cool CA
    I really can't answer that precisely, the wiring should be the same as the extension that you are using, if you are using one, if not, the same guage the EVSE has. The wiring of course depends on the physicality of the switch, since we are talking about a very short distance 6-10 inches. You could even make two short pigtails with two wire nuts. On the 2005 I used a very sturdy Battery disconnect switch, but I think that was overkill.
  8. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    I didn't know I have a reboot switch?? So did your estimated or actual range (or both) go up? I know disconnecting the battery and reconnecting causes the estimate to reset.
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Isn't this pointless because actual EV range is not changed?
  10. 13Plug
    581
    105
    2013 Prius Plug-in
    That's my thoughts, just waiting for clarification from the OP.
  11. Andyprius1
    2,327
    859
    Cool CA
    . That is correct. The estimated, however the total range is determined by the estimate, isn't it ? There is no reboot switch on the car, but, you may install one. I found it useful on my 05 as well.
  12. Andyprius1
    2,327
    859
    Cool CA
    I never said that, somebody else said that. Anyway, figures don't lie, but liars figure. Don't wait for my advice, try it and see.
  13. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The total range is based on the total charge and the driving conditions during this particular discharge session.
    This is akin to resetting your fuel economy gauge then expecting to get more miles out of a tank. The amount of fuel in the tank remains the same regardless of any electrical shenanigans. :)
    If it works then I'll happily eat crow.
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Figures don't lie? You obviously have not taken statistics. LOL
  15. Andyprius1
    2,327
    859
    Cool CA
    remember that apparently not only is the estimate dependent on temperature but the actual charging rate seems also to be dependent on temperature. What is the ideal temperature? Unknown, but probably something in the temperate range.
  16. Andyprius1
    2,327
    859
    Cool CA
    . Start eating, as I have never seen a fuel economy guage that one could reset. All mpg guages that I have ever seen only read out present results.
  17. bisco
    52,747
    i can confirm this. i'm charging much faster in the last two weeks than i was in jan. and feb.
    Andyprius1 likes this.
  18. Andyprius1
    2,327
    859
    Cool CA
    there is no such thing as actual EV range, this is all determined after the car runs out of EV charge, providing you havn't polluted the trip with HV mode. Shame,shame.
  19. Andyprius1
    2,327
    859
    Cool CA
    I'm partial to real world results, statistics lie, obfuscate! confuse and definitely help the writer that is trying to prove a point. But, are the numbers correct? No I am not a statistics expert. What does that have to do with the subject matter.
  20. Andyprius1
    2,327
    859
    Cool CA
    Your taking my statement out of context. But I get your drift.
    F8L likes this.
