REBOOTING
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Andyprius1, Nov 11, 2013.
  1. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    So, after 473 miles of continued EV use, I had to ruin it with a trip. But decided to reboot and try to raise my estimated range. So I rebooted, but this time left the 12 V battery OFF all night. That seems to do the trick, as I raised it from 11.1 to 13.9 miles.
  2. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    what do you mean by a reboot
    a simple on and off?
  3. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
  4. Andyprius1
    2,327
    859
    Cool CA
    Disconnect the 12V battery, I made it simple by putting a switch in.
  5. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    I don't see how that helps with range you are simply tricking the counter to rest I think and also you lose all your preferences nothing actually changes
    Turn off signatures in Tapatalk Tapatalk
    retired4999 likes this.
  6. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Have you actually tried using the trip computer to calculate it instead of the estimate
  7. striker308
    302
    43
    My EV cuts out at 14mph, and even then I cant use it till Ive driven the car for at least five min to warm it up.
    without being a plug in its of no use to me, we drive faster than 14mph in parking lots around here.
  8. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    We are discussing the plug in prius
  9. striker308
    302
    43
    My bad, sorry
    small screen I didn't see the "plug-in"
  10. vskid3
    vskid3 Active Member
    773
    228
    All it resets is the estimated range. I would bet that the distance you actually go in EV is the same before and after.
    retired4999 and Priusmpg like this.
  11. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Same here
  12. retired4999
    2,652
    627
    Eau Claire, Wi.
    You are correct! (y)
    Priusmpg likes this.
  13. bisco
    52,849
  14. Andyprius1
    2,327
    859
    Cool CA
    This is a PIP forum.
  15. Andyprius1
    2,327
    859
    Cool CA
    Hi friendo.
  16. Andyprius1
    2,327
    859
    Cool CA
    If you haven't tried it don't knock it!
  17. retired4999
    2,652
    627
    Eau Claire, Wi.
    See post #9 above.
  18. retired4999
    2,652
    627
    Eau Claire, Wi.
    Does not matter what the estimate number is.
  19. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    It has to make the littlest of sense to try it. Your theory has no logic behind it
  20. Andyprius1
    2,327
    859
    Cool CA
    That would have to be proved under very strict, laboratory conditions. Too many factors determining actual range, temp, acceleration, altitude, mood, pressure, wind, wind direction.
