REBOOTING
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Andyprius1, Nov 11, 2013.
  1. retired4999
    2,652
    627
    Eau Claire, Wi.
    Ah! Got me! at mid summer I was at a high of 18.2 EV Est. Yesterday it was a high of 26 degrees f, so this early winter I am down to 12.2 EV est.this morning. :) I think last year mid winter I was down to about 9.1 EV est. Bring on spring!
    Biking Maniac likes this.
    52,740
    we have lots of slow driving, 24 mph average, and my commute is almost 15 miles which i make easily between may and september. no big hills either.
  3. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Agree on Israel sounds perfect (in many ways).
    As for 'rebooting' as you put it, I am with other posters here, it will only prove me what I already know: I am beating "Toyota estimate for the average driver" in average commute route, traffic and topography at average temps.
    Astolat likes this.
  4. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Right, a 12V source is required to put the car in ready, once obtained, the battery can be disconnected and the car still runs fine. A bit wierd ? yes.
  5. Andyprius1
    2,327
    859
    Cool CA
    How did you make those two additional notes on the bottom, referring to previous Prius ownership. I use a IPad. TY.
  6. Andyprius1
    2,327
    859
    Cool CA
    Garage kept PIP or street parked ? Colder temps are definitely the main determinant. My residing in CA and garage parked are probably big factors to higher estimate.
  7. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Open, near street parking spot (under roof).
    As to your second question, its my signature. You can create yours, go to andyprius1 drop down menu and then signature. Hope you are not pulling my leg...;)
  8. Andyprius1
    2,327
    859
    Cool CA
    TY Giora, No, not pulling your leg. Surprise, it worked!
  9. Andyprius1
    2,327
    859
    Cool CA
    The street parking comment was directed toward Eau Clair, Wisconsin, that's the reason for the confusion, TY for the signature elucidation.
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    Garage kept! 45 degrees, Yes does help alot when really cold, Esp. when 0 degrees to -25 degrees f.
  11. Andyprius1
    2,327
    859
    Cool CA
    Yes, I spent 4 yrs + in Madison. One day it got down to 29 below zero! Not really too cold in Arctic terms, but, the humidity was so high that the cold just bit right thru you. Having spent a year at Thule, Greenland at 65 below zero, was warmer than Wisconsin. I wonder if there are any Prii in Greenland? Alaska will do. Fairbanks gets rough.
  12. retired4999
    2,652
    627
    Eau Claire, Wi.
    Does not happen often, but I have been out in Alexandria, Mn. at -42 below f, and you will relate to this. The snow has a special crunch to it when over -40 f. It's special! :D
  13. Andyprius1
    2,327
    859
    Cool CA
    Right in Thule for about 6 months. Also, since it is as dry as the desert, perhaps drier, one could draw a spark on the metal door handles from 1/2 to 1 inch. I tried to remember always to wear gloves.
    retired4999 likes this.
  14. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Where I was born, temps are going above 120 F 2-3 times during each summer. The record was 132 F (very dry though).
  15. retired4999
    2,652
    627
    Eau Claire, Wi.
    Right a dry heat!!!! Just like a oven! That is just down right ugly! :whistle:
  16. Andyprius1
    2,327
    859
    Cool CA
    Actually a dry heat or cold is preferred, In that respect the far west and Israel resemble each other. I remember laying on grass by the University of Wisconsin, sunning myself and constantly sweating. which is unusual for me. And originally coming from NYC, which has relatively high humidity, caused some wonderment , I never really figured it out, I presupposed it was a Great Lake effect.
  17. Astolat
    Astolat Member
    229
    73
    Guildford UK
    Looking forward to seeing the results!
  18. Andyprius1
    2,327
    859
    Cool CA
    Thankyou, I am so glad that somebody is willing to test this theory. Rebooted again today, and it reverted to 13.9 again. Also my experience has been that the range always exceeds the estimate. So, higher estimate = higher range / for a given temperature. ( many other variables there as well).
  19. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    This is turning into a Monty Python sketch.
  20. Andyprius1
    2,327
    859
    Cool CA
    We are definitely riveting!
