REBOOTING
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Andyprius1, Nov 11, 2013.
  1. Astolat
    Astolat Member
    229
    73
    Guildford UK
    I'm afraid I'm in the camp that thinks this is complete nonsense, it's the equivalent of a perpetual motion machine, creating extra mileage out of thin air. I'm looking forward to the results proving you wrong...!
  2. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Maybe we should add a cold fusion charger in the trunk as well.
    Mike
  3. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Rebooting, Quote: "Is a time honored method of getting a computer to work correctly" All Prii have several computers on board, all of them have a desired base start system. The first reboot is by Off/on of Power button ( for minor glitches ), A standard procedure. The next type of reboot is the removal of one connection on the 12V Battery. Your choice. I prefer the Negative. I have put a switch on for my own convenience. Should I have a major problem, a Red Triangle, I only have to hit the switch. So far we have been lucky with the PIP and the C, maybe Toyota fixed all those glitches which turned into major problems for the customers of previous generations. Definitely not perpetual motion! But only a return the the specified base when a bit out of wack. Please do not await the results by "other" people, DIY
  4. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Rebooting is not a way of getting a computer to work correctly. Rebooting simply puts the computer into a known state. In the embedded consumer world where things are cheap and poorly programmed, rebooting "fixes" things because the code has gone off into the weeds taking a branch that "was never supposed to happen". For a device with a full operating system that the user can control and modify, like a consumer computer/phone/tablet/whatever, most of the instability does not come from the core code but from all the little add-on packs that consumers insist on installing from hundreds of different disjointed vendors that do not always play nicely together. A reboot in that situation puts everything into a known state again where any ill advised interactions between processes is halted at least temporarily.
    An embedded automotive computer shares no resemblance to anything else that you own with a power button. There are also failsafes and watchdogs built in that automatically reset the code and keep track of it if it runs into the weeds with an accompanying error light on the dash saying some bad has happened. What you are doing is not so much resetting the computers, as re initializing the variables.
    The 1 and only premise for any argument that can be made is that you somehow continually are able to make the Prius store in its less-volatile memory variables and fudge factors that when combined create erroneous readings of the battery's state of charge. And we call hooey on such a silly assumption especially when backed up with no data. Something that you are continually able to find that nobody else in all the man years of Toyota testing over the decades from 1993 have ever found, you are able to find and reproduce consistently...
  5. Astolat
    Astolat Member
    229
    73
    Guildford UK
    Bumped, in the hope that Priusmpg has some stats for us. Will PM too.
  6. Shirjeel Agha
    Shirjeel Agha Junior Member
    31
    Lahore, Punjab, Pakistan
    is there a third way for rebooting the computer because these two have not helped.
  7. Mendel Leisk
    42,219
    Hey, don't start introducing reality... :ROFLMAO:
  8. bisco
    52,740
    what problem are you having?
  9. Shirjeel Agha
    31
    I have started a new conversation stating my problem and included your name in the participants. Please see the description there. Thank you.
  10. bisco
    52,740
    first, check your 12 volt battery. then test the hybrid battery, if it is dead, you need a special charger that only the dealer has. do you have a dealer in your area?
  11. Shirjeel Agha
    31
    I have checked the 12 V battery, it is charged and working fine. We have dealers but they only sell conventional hybrids. Trying to find a local mechanic or electrician who can help me with this.
  12. bisco
    52,740
    you should start a new thread in the plug in forum. or even the gen III care, maintenance and troubles forum, to hopefully get some experts looking at your problem and asking questions.
