Rebuild 1st gen engine
Discussion in 'Generation 1 Prius Discussion' started by 2002_Pri_Rod, Apr 5, 2018.
  1. 2002_Pri_Rod
    2002_Pri_Rod Member
    92
    69
    Forestville, CA
    2002 Prius
    Hey Everyone
    I was looking through old threads and was not able to find a thread about rebuilding the internal combustion engine on a gen 1.
    Has anyone done this? Is it practical as a lot of these gen 1s are heading over 200 K miles?
    52,805
    can you find a decent salvage for cheap?
  3. 2002_Pri_Rod
    2002_Pri_Rod Member
    92
    69
    Forestville, CA
    2002 Prius
    There are 4 1st gen Prii in a pick and pull near me - I am going to see what kind of condition they are in - don't have time for a new project right now but we have a 2001 and a 2002 with 200 K and 212 K miles respectively
    If the engines look ok might be a good time to pick one up and stick it in the back of the garage
    Raytheeagle and bisco like this.
    52,805
    i can't speak for gen 1, but gen 2 and 3, it is usually much cheaper to pick up a salvage than rebuild. but they may be more plentiful.
  5. 2002_Pri_Rod
    2002_Pri_Rod Member
    92
    69
    Forestville, CA
    2002 Prius
    Agreed - I am even curious if rebuild parts or kits are available for Gen 1s -
  6. tada
    tada Member
    73
    77
    Tucson, AZ
    2002 Prius
    It looks like RockAuto carries a lot of internal parts and gaskets. Heck, they even list a long block but it’s out of stock.
  7. ChapmanF
    18,990
    The Gen 1 and Gen 2 (and c) engines are somewhat impractical to rebuild, as the valve clearance adjustment is made by select fit of the bucket lifters. I did say the lifters; the system doesn't even use separate shims. You need the lifters themselves, which are sold in 35 different sizes and you need enough of an inventory to pick the right 16 based on the clearance measurements of your 16 valves. Obviously, this is easy at the factory. It's an expensive PITA even for a dealer, and pretty much impractical for DIY. (One exception might be if you're really on such a relaxed schedule you could afford to trial-assemble, measure clearances, then calculate the exact lifters to order, and wait for delivery.)
    The Gen 3 and later (and v) 2ZR engine is more inviting for DIY rebuilds, as it uses hydraulic lash adjusters. All you have to do is make sure those work (i.e. aren't stuck and the check valves work) or replace any that don't (only one size to choose from), and they do the rest.
    -Chap
  8. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    Has anyone even heard of a classic Prius IC going bad? Not much of a problem judging from the posts here. As for storing parts in the back of the garage (or in a spare closet,) sure, maybe. But it really is the least likely and last component that will go wrong. Why, you might ask, is this the case?
    Well first of all, it's a Toyota! I had '70 vintage Toyotas that went to 300,000 miles with only things like water pumps and distrbutors going bad. Toyota quality should be and is legendary. My classic has 205k miles and doesn't leak or smoke or run funny.
    Second, people that bought classic Prius's tended to be early adopters, environmentalist drivers. Smarter than the average bear, BooBoo! Both of my cars came to me with fresh synthetic oil, clean, fresh coolant, and proper transmission fluid. Our predecessors took great care of their cars and it shows these many miles and years later. My 02 really does feel like and runs like a new car--better in most senses. Thanks Linda L!
    Three, it's an economy car. No teen and twenty somethings trying to wring more hp out of the little engines. And the owners of Prius's (myself excluded) then to run their cars with reasonable throttle and reasonable expectations.
    Four. It's a hybrid. The electric drive makes life a lot easier for the IC. Think of it as an always on supercharger. Brilliant design, imo!
    Did you guess I love my classic? I would consider newer Prius, but they really are just so homely!
    WHCSC likes this.
  9. ChapmanF
    18,990
    Nevertheless, my Gen 1 had finally begun to show some uneven compression numbers the last time I checked it (at around 226k miles), and my Gen 3 already by the first time I checked (at around half that).
    Time and miles wait for no engine....
    -Chap
    #9 ChapmanF, Apr 6, 2018
  10. 2002_Pri_Rod
    2002_Pri_Rod Member
    92
    69
    Forestville, CA
    2002 Prius
    Yep Brian I agree with most of your comments but at the end of the day even Toyotas need a little love - I drove a 22RE motor in another set of vehicles for nearly 400000 miles with a rebuild at 200000 miles - I ask about rebuild potential because one of our two Prii is getting some pretty good blow by (oil in the intake) and the last time I was in the local hybrid repair shop they had a 1st gen Prius they were replacing the ICE and the hybrid traction battery.
    Second reason is that most of the 1st gen Prii I am seeing for sale are close to or over 200000 miles - and these 15 year plus cars are starting to show up in the junk yard - I am thinking that the time to stock pile parts if you have time and space is when they are available
    I also love my little car and want to see if I can get 400000 miles out of it
    Brian in Tucson and Raytheeagle like this.
  11. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    You can take Chap's word to the bank on rebuilding these things.
    The only problem with getting a used engine is that you won't know the mileage on it. Unless, of course, the wrecking yard wrote it down somewhere.
    You'll probably have to just take parts from the nicest one. I've seen some pretty pristine examples in the local P'n'P yard. A boroscope won't tell you enough & and gives you no indication of the condition of the rings, valve faces, etc. Same with pulling the pan off, you can look at the cylinders and sneak a peek at the bearings, but it's only a look and a peek. OTOH, pick n pull is pretty inexpensive and even has 'sale day' when the engine prices are practically giveaways. If you plan to store an engine--see if you can squirt in fogging oil in to the spark plug holes and then store the engine in a garbage bag and up on a pallet.
    You might see if you can purchase the transaxle, a nice inverter, and a brake booster pump. If you pick an a/c compressor, be sure to seal up the connections Duct tape will keep dirt out just fine, and then put it in a trash bag and seal it right up. You live in a pretty dry climate, but prone to dust and dust is not your friend. Inverter coolant pumps and suspension & steering parts (except for the rack) aren't worth picking.
  12. 2002_Pri_Rod
    2002_Pri_Rod Member
    92
    69
    Forestville, CA
    2002 Prius
    And of course I would have to hide the parts from my wife - I hope to get to the junk yard on Saturday - will see if it makes sense at all
    Raytheeagle likes this.
  13. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    For me, I won't spend that time rebuilding a gen1. I'd rather get used motor from a junkyard.
  14. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    I think that's what we decided.
    Think about what a hero you'll be when you can fix her car with cheap, heck even free, parts.
    #14 Brian in Tucson, Apr 13, 2018
  15. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Which pick n pull you hittin’ up tomorrow :whistle:?
  16. 2002_Pri_Rod
    2002_Pri_Rod Member
    92
    69
    Forestville, CA
    2002 Prius
    I am heading over to the Windsor pick n pull - they say they have three there
  17. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Looks like there are even more within a 100 mile radius too;).
    Happy hunting tomorrow (y).
  18. 2002_Pri_Rod
    2002_Pri_Rod Member
    92
    69
    Forestville, CA
    2002 Prius
    So what about buying a new head - I see online you can order new heads for the ICE
    My engine has a lot of blow by ( intake on my wifes 2001 is dry as a bone and has been for the last 6 years) and I have been told by a credible local hybrid repair shop that it likely needs new valve guides
  19. ChapmanF
    18,990
    Are the heads on offer fully assembled? I don't know, I've never checked.
    -Chap
  20. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    The description on Rock Auto says that they are. Whether that includes the lifters, who knows? But the description says that the cams are included.. All for about $400.
    Rod, no luck at the pick n pull? If you could find a likely candidate, you could even buy just a head and switch it out.
