Rebuild Engine/Cat or Replace the Whole Car?
Discussion in 'Gen 3 Prius Main Forum' started by theheapstoe, Dec 12, 2022.
  1. ChapmanF
    19,025
    If I'm reading right, the concern is that the engine is using oil, and that the oil usage might be what has led to the catalytic converter code.
    But at 12 years and 146,000 miles, some of the reduction in O2S capacity might just have been happening more slowly and all along. Those converters don't last forever.
    While the OP has mentioned the oil consumption, I don't see any specific mention of how much oil it's using.
    But if the CA emissions warranty is just for 150,000 miles, there are only 4,000 miles left to go have that conversation at a dealer.
    I've heard that consideration often carries a lot of weight.
  2. theheapstoe
    theheapstoe Junior Member
    26
    Coulterville, CA
    It does! haha. My oil consumption is pretty heavy, basically an oil change every 800 miles.
    If I looked at my warranty correct, it expired after 8 years. Do you know how I can verify that?
  3. JC91006
    16,936
    8,647
    The easiest way is to call a knowledgeable dealer and ask. They should ask for your VIN and then let you know. I would ask more than 1 dealer, just in case the one you asked doesn't really know the CA emissions warranty
