Rebuilt 2006 Prius Battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by briansterling, Oct 6, 2013.
  1. briansterling
    briansterling Junior Member
    47
    May just do that. Standby.
  2. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I chatted with Dave recently. He is working for Dorman and still developing lithium options as hybrid replacement batteries.
    Jeff
  3. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    That is good to know. I saw the acquisition online and posted it here on PC recently. Lost David's # since the last time I talked to him. Also glad to hear he is still working on the lithium. Any ideas on who is honoring the warranties now since Dorman took over? Sorry for being off track of the OP's post.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Slow charging 12 volt battery is sign of sulphated battery. Its done. Forget it.
    Hook the charger to the front jump points of the car and attempt to make the car READY. FIRST Make sure the pos connector with the fuse assy in the trunk that was hooked to the now absent battery is covered up first so it can't short out. You have bad luck lol......
  5. edthefox5
    10,096
    4,837
    Clearwater, Florida
    But first clear all the codes. If a Prius has a fatal Hybrid battery assy code sometimes it will not start unless its cleared first. Safety issue.
  6. dorunron
    3,318
    1,105
    Houston, TX
    Ed, no offense but he is limited to two amps so its going to be slow...
  7. jdenenberg
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My ReInVolt is way past warranty (and it is still going :)). Dorman puts a three year warranty on their rebuilt batteries.
    JeffD
  8. dorunron
    3,318
    1,105
    Houston, TX
    Got it, makes sense to me now. I googled David again and see the connection to Dorman now. Glad to see he is still involved. Smart move for everyone IMO. Sorry for being off topic, back to the topic...
  9. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    Brian, have you tried clearing the codes? The car won't pull the contactor's down if it detected the short.
  10. briansterling
    47
    By "clearing codes" do you mean holding down the ODO button when powering on? I know that will clear the dash warnings but I don't know if it will clear the codes. I don't have access to an auto scanner anymore.
  11. dorunron
    3,318
    1,105
    Houston, TX
    Clearing codes is usually done with a scanner. Some of the codes were cleared when you unhooked the battery, but there may still be some stored one's. I do agree with Ed and goldfinger, that the Prius may not go into ready mode if certain codes are set. Toyota's safety issues...
    All the hold down of the ODO button does is "reset the maintenance light".
  12. goldfinger
    535
    403
    Buffalo
    No, you need a scan tool that knows the proprietary Toyota codes. It sounds like your friend has one. Most here use cheap scanners with usbseawolf2000's pid codes for Torque.
  13. edthefox5
    10,096
    4,837
    Clearwater, Florida
    None taken.
    I'm not worried or care about the 12 battery it's just another question mark in his no start problem. Forget it. Eliminate that off the check list. Pump in 12 up front and try to ready it.
  14. briansterling
    47
    This battery is taking forever to charge. I'm going to pipe in 12v from another vehicle and try it. I'm assuming I can attach the jumpers to the frame and the little lug underneath the red cap in the fuse box?
  15. dorunron
    3,318
    1,105
    Houston, TX
    You can, but remember what I said about the polarity. Don't reverse it! Positive on the jump post, negative on the frame. If you get it backwards, 4K damage instantly! Read the owners manual for the correct technique and follow it when hooking up and unhooking.
  16. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Better off using the charger. Less current the better. You need just enough current to boot the relays. So many reports of Armageddon damage upon jump start. Pos to the red cap and usually everyone uses one of the nuts that holds that driver side strut on as the neg. One of the 3 nuts on the strut tower. You'll see it it's right above the that fuse box.
    If you must use another vehicle do not run the donor car engine.
    Under the red cap is a vertical metal attachment tab bolted down. A little L plate. You attach the jumper clip there not to the nut itself under the red cap. If it boots you can disconnect the charger while its in ready. Disconnect neg first. The Inverter will keep the 12 volt hot.
    Btw, I maintenance charge my 12 at least once a month on the front jumpers. Alot of us here do this. I do it on all my cars. Its very good for the battery. Got 6 years out of my oem till one day out of the blue I noticed its throwing a red exclamation point on the dash upon start up. That means the 12 dipped to 11.2 or below on boot up. It only shows it on start up and does not log a DTC. It's the only warning you get. Yours threw it too you just never noticed.
    I knew what it was and threw my charger on it and sure enough the current meter just sat there. Happened fast. Son of a b*tch.
    Next day I bought a Yellow top. Still charge it once a month. I want to see what the current meter does. When the 12 fails it does it fast. I don't want to be stranded and holy god I don't want the wife to be stranded. And she never has. Don't dick around with a soft 12 in this car. Its really dangerous to your wallet. It will leave you and force you to get a jump.
  17. briansterling
    47
    Okay so I hooked up the donor vehicle and nothing went boom. Still had the same warning light and no contactor click. The battery finally got to a decent charge and stuck that bastard back in there and still more of the same. I know the contactors/relays are good, plug fuse is good, and I know the 12v battery is too. I'm hoping upon hope that a new ECU will fix my issues. The "lost com with battery energy control Module A" was my error code and I'm assuming the "module A" is the ECU that's beside the battery and not the one in the glove box.
    Could it also be a probability that since I didn't "clear" my codes before giving the scanner back that the car is hung up on the a code for safety reasons and has shut down my ECU until the code is resolved?
  18. briansterling
    47
    I think I will go with an optima. I've used those in some EV vehicles I've helped build and they were top notch when lithium was too expensive.
  19. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Yes highly likely codes are stored. Fatal Hybrid codes should be cleared before boot attempt. Anything to do with Hi Volt may keep the car from booting until cleared by what Japan can only hope is the dealer. I think....
    Plus repeated failed boot attempts will fail safe it too. It's like putting in the wrong password in a pc. More than 3 times it will lock you out.
    Most of the time a disconnect of the 12 will clear it though.
    I have an Optima. So far so good. The Prius charges it to 12.8 in its daily travels. Try to maintain it once a month to show it the good life.
    if you buy an Optima make sure you fully charge it before bolting it in as many reports of very low charge Optima after install. Plus you get to check its health by charging it. If its a mutt back it goes.
    The smallish Yellowtop is not a big seller apparently in certain areas of the country and may sit on the shelf a while.
    There's alot of alternatives out there also including the Exide.
  20. briansterling
    47
    Well that's confusing because I had the 12v disconnected for quite a bit. I'll try and reborrow that scanner to clear the codes just in case. If that doesn't do it I see no alternative but to buy an ECU. If that doesn't work I have to get it towed to the local Toyota dealer and hang my head in shame before the technicians.
