Rebuilt engine or a 2013 Prius engine with 100k miles
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mitzie, Sep 8, 2022.
  1. Mitzie
    Mitzie Junior Member
    CA
    I have a 2011 Prius with head gasket symptoms that I was wanting to get rid of but didn’t, and now a friend would like to have it repaired so he could use it while he’s here temporarily for a few months. 2011 Prius has 216k miles. We have consulted before & were advised that engine replacement is the way to go. Is a 2013 original Prius engine with 100k miles a better option than a rebuilt engine? Thank you.
  2. JC91006
    16,936
    8,647
    100k miles vs rebuilt, ultimately comes down to how truthful the mechanic is about the 2 engines. If they both work properly, it would not matter for the few months you intend to use the car.
    mikey_t and Mitzie like this.
  3. Isaac Zachary
    Isaac Zachary Senior Member
    2,779
    1,501
    I wouldn't trust a rebuilt modern Toyota engine. This is because you can't bore or hone them. So if there's any damage to the cylinder walls, which is usually the main reason you rebuild an engine, your engine is essentially un-rebuildable.
    A new short block is a possibility though.
    douglasjre and Mitzie like this.
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,116
    6,974
    Texas Hill Country
    Update the 2013 engine with new pistons, rings and gaskets while its out. Which is exactly what Toyota did if it was responsible for a "rebuild" during the 60k mile powertrain warranty.
    Mitzie likes this.
  5. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    If the 13 has 100K on it you got about 130 to go and then it's probably going to pop a head gasket and if the car isn't worthy of shape you'll buy a JDM spec Gen 4 engine or by then maybe Gen 5 who knows and stuff that in there or you'll walk away and get another car just just did this a few months ago the JDM in my 2013 to me the best way to go all lower mileage and what I had and not from around here
    Mitzie likes this.
  6. JC91006
    16,936
    8,647
    If you can choose, I guess the engine with 100k does sound better. But not sure how you can verify the engine actually has that mileage on it.
    Raygon and Mitzie like this.
  7. Mitzie
    CA
    Thank you all for your input. We’re leaning towards the 2013 engine. I also wonder how I can verify the mileage on the engine..
    douglasjre likes this.
  8. bisco
    52,861
    how bad is your current engine?
  9. PriusCamper
    PriusCamper Senior Member
    13,467
    5,434
    Pacific Northwest, USA
    Yes, but best practices to deal with with Gen3 Engine (headgasket, bad piston rings that burn oil) is to swap it with a used Gen4 engine.
    Isaac Zachary likes this.
  10. PriusCamper
    13,467
    5,434
    It's really a matter of who's doing the work, how much they're charging and how much you can afford. If you just need to get it back on the road for a few months before you sell it, finding a friend or family member who works on engines to just do the head gasket is the way to go. It will be way more affordable than what a shop will charge. There's also mobile services that specialize in doing these because they're so common and it takes them less than a day to do it because they do them so often.
    Mitzie likes this.
  11. JC91006
    16,936
    8,647
    Mobile service? meet them at 7-11 and pay with cash?
  12. PriusCamper
    13,467
    5,434
    JC91006 likes this.
  13. PriusCamper
    13,467
    5,434
  14. rjparker
    11,116
    6,974
    Texas Hill Country
    It should have a vin plate which then can be checked with carfax. However most salvage engines are conveniently missing the vin plate leaving the mileage a crap shoot from guys with far worse reputations than used car salesmen. JDM engines never had the US vin plates.
    Which is why the smart move is to do a ring and gasket job on a used engine. I would not risk a rebuild on a known head gasket failure engine. But if 50k miles is your goal you can roll the dice. However I would change casinos to LKQ salvage, perhaps the most reputable junk yards.
    Mitzie likes this.
  15. JC91006
    16,936
    8,647
    I'm not sure how comfortable I am with a mobile head gasket change. These things are never that straight forward, once opened up, the guy would want to finish and get paid. Every car engine is different, there may be issues with one engine and a different issue with a different engine. It cannot be a one size fits all type of service. Whether or not it's done correctly, it'll need to be done to get paid and get home. Not sure I would trust that type of repair
    Mitzie likes this.
  16. rjparker
    11,116
    6,974
    Texas Hill Country
    They bring a truck full of machined heads, cleaned egrs, even rebuilt engines. So if its more than a gasket you have a choice.
  17. AzusaPrius
    AzusaPrius Senior Member
    2,257
    945
    You can also head over to hybridpit in Buena Park and tell them Azusa sent you.
    You can also use the code azusa on their website hybridpit.com to save some cash.
    I got a rebuild from them and was able to pick from 3 different engines with vin plates and I picked the lowest mileage.
    They then did their magic on it and its been great for a year now.
    Check out my profile for helpful links.
    Mitzie and mikey_t like this.
  18. JC91006
    16,936
    8,647
    So how much does one expect to pay for all those services? Wouldn't it be cheaper to just put in another engine?
    So it's advertising for a cheaper head gasket job, but ends up being a rebuilt engine at what cost?
    Mitzie likes this.
  19. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    I second going to HybridPit for a rebuilt engine. I recently got one to replace my 2010's engine and it's been really great, plus the final invoice was less than what the dealership quoted me for a headgasket job and what it would've cost to buy a JDM and have someone install it. They do quality work there. If you're in Southern California I think that's the best solution and value; using a band-aid to cross your fingers on the car running for a few extra months usually isn't worth it.
    Mitzie likes this.
  20. Mitzie
    CA
    I haven’t had it looked and the recommendations I got are based from symptoms of loud knocking sound and losing coolant. Most places I’ve asked based on these have said that engine needs to be replaced.
