Recall for Prius Plugin fuse :-)
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Sandollar, Jan 23, 2018.
Tags:
  1. Nasir kh123
    Nasir kh123 Junior Member
    Pakistan
    Ok,thanks
  2. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    Day 1 of my regular commute after the fuse recall work was done.
    Car performs the same. Full EV all the way to work (with a few down hill grades to help out. On the way home, up those hills, the ICE ran a little as usual.
    I’ll run the rest of my week and post results/experience.
    jerrymildred and Raytheeagle like this.
  3. Nasir kh123
    Pakistan
    What is full EV MODE now?
    I have 2014 after full charging it shows 19.4km
    But when i drive with light foot ,low speed,withot ac it runs maximum 16 km
  4. Yea Right
    232
    115
    Seattle
    2014 Prius Plug-in
    My 2014 with 35K miles was at 14.4 miles at full charge this morning. Temperature was about 50 degrees Fahrenheit.
    Pakistan has mid 80s to low 90's, so your 19.4K (12 miles) seems a bit low, especially at those temps. How many miles on your 2014?
  5. Yea Right
    232
    115
    Seattle
    2014 Prius Plug-in
    Kinda boring results ... After 5 days of my regular usage/commute, everything seems to be just like the fuse change out never happened.
    Business as usual.
    KevinPluggedIn likes this.
  6. Nasir kh123
    Pakistan
    Myprius with 31 k,In very begining when prius was delivered to me ,one day i heard a sharp clicking sound was comin from back side, first time when i opened the cover of hybrid battery and checked ,there were two fans one fan was making moise ,a piece of fan was broken i cut and separated that piece everything was fine,maybe that,s the reason?fan is not doing its job 100%, Maybe hybrid battery is getting hot?
    Temp here now a days is 32c to 39c
    Should i change fan ?or any other advice?
    SAMSUNG-SM-N915A using PriusChat mobile app
  7. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    A fuse is just something that burns when it exceeds some power
    So obviously the car will perform EXACTLY like before, except in the rarest of cases when it might have burn the fuse, in which case it will not, now
  8. bisco
    52,863
    change the fan
  9. bisco
    52,863
    it depends on many factors
  10. SlidingBike
    SlidingBike Active Member
    171
    113
    Fremont, CA
    Just FYI: If any of you are left the recall without fix on your car, you may likely have an issue in registration/renewal like me. This recall MUST be done before DMV issues the online registration notice, if not, you would end up in getting this recall done ASAP and starve your bald head in the super hot sunlight under the sky in the DMV lines.
    #110 SlidingBike, Oct 16, 2018
  11. bisco
    52,863
    ugh! one of the downsides if i can move to cali.:rolleyes:
    Raytheeagle and SlidingBike like this.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    You mean when:p.
  13. Yea Right
    232
    115
    Seattle
    2014 Prius Plug-in
    This bald head ain’t moving to Cali :p
    jerrymildred and bisco like this.
  14. SlidingBike
    171
    113
    Fremont, CA
    At last I am (forced to be) done with my PiP fuse recall. Damn Toyo dealer took a full day to do this.
  15. bisco
    52,863
    i'm still thinking about it...
    SlidingBike likes this.
  16. Bucky35
    Bucky35 Junior Member
    37
    NorCal
    Any east bay dealer recommendations? Was hoping to avoid this recall but just got the dreaded DMV no renewal demand.
  17. Bucky35
    37
    NorCal
    Ok, took it to Dublin Toyota. 2 1/2 hours for the recall work to be performed.
    SlidingBike, jerrymildred and bisco like this.
  18. bisco
    52,863
    not too bad
  19. Civiceg94
    Civiceg94 Member
    60
    45
    Nyc
    Had mines done along with the side curtain airbag bracket took them about 4 hours. At least i got a loaner.
  20. bisco
    52,863
    good deal.(y)
