recall: inventer software update
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Zaza 13, Jul 21, 2019.
  1. Zaza 13
    Zaza 13 Junior Member
    74
    Israel
    recall: inventer software update. has someone any expirience?
    52,863
    yeah, there are a few threads here with lots of posts. they change some transistors or something to keep it from overheating under high stress.
  3. Robert Holt
    Robert Holt Senior Member
    1,313
    890
    My understanding was that the software was changed to avoid prolonged, high-current draw through the inverter’s power-output transistors , which can over-stress and kill them. That may have also caused a very slight decreased in power available from the motors under high load conditions.
  4. Chris Loyd
    Chris Loyd Junior Member
    Ball Ground, GA
    Just got the J0V update yesterday, no issues so far.
    Zaza 13 and Threej like this.
  5. sguerra923
    sguerra923 Junior Member
    48
    San Diego
    Can we call our local dealership to get this done? I just got a check hybrid system check engine light and cleaned out my hybrid cooling fan and so far no check engine but my Prius has been sluggish before and after the cleaning. My car also tends to rev high when I'm idle at a stoplight at times..
  6. bisco
    52,863
    of course. have you cleaned the egr circuit?
    Zaza 13 likes this.
  7. sguerra923
    48
    San Diego
    Yes actually got it replaced
  8. Threej
    Threej Member
    99
    99
    Portland, OR
    Got my J0V done last week, so far so good.
    Zaza 13 likes this.
  9. schmuber
    schmuber Member
    115
    85
    Georgia
    Somehow I doubt that they've replaced the EGR cooler.
  10. sguerra923
    48
    San Diego
    Why is that?
  11. schmuber
    schmuber Member
    115
    85
    Georgia
    You're not hysterical about the labor cost.
  12. sguerra923
    48
    San Diego
    It was covered under warranty
  13. schmuber
    schmuber Member
    115
    85
    Georgia
    If I'm not mistaken, the official procedure for replacing the EGR cooler requires removal of the engine. I still doubt that they did it, warranty or not.
    More likely they've replaced the EGR valve and called it a day.
    Raytheeagle likes this.
  14. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    You don't have to remove the motor to remove the cooler.
    Just the windshield wiper assembly, which is very easy to do, about 10-15 minutes.
    pingd likes this.
  15. schmuber
    schmuber Member
    115
    85
    Georgia
    It's a hack pretty much exclusive to this forum.
  16. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    EGR replacement?
  17. sguerra923
    48
    San Diego
    Yeah I had bad knocking noise from cold starts and they heard it and was able to replace it under warranty
  18. bisco
    52,863
    they were replacing intake manifolds, iirc
  19. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Did you get that in writing? "EGR replaced"?
  20. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Well also need more than the three letters EGR:).
    What’s after it is just as important: valve or cooler;).
    If just valve, there is a lot of work left:cool:.
    Good luck and keep us posted (y).
    pingd and CR94 like this.
