Recall
Discussion in 'Gen 3 Prius Main Forum' started by ttou68, Jun 24, 2020.
  1. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Dipsticks must be a delicate item for them to handle.
  2. Fitcious
    Fitcious Member
    195
    88
    Los Angeles
    If it’s a safety recall and you’re in California- you cannot renew the tags on your car until the recall is done. That’s what happened for my FRS last month
  3. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    I got my CA tags two weeks ago and Never got the recall done. Just got an email from carfax to git r recall done yesterday.
  4. El Dobro
    El Dobro A Member
    7,102
    3,282
    What did they do, put a popsicle stick in the hole?
    Threej and Majafamily like this.
  5. Freeze Time
    Freeze Time Member
    161
    50
    Huntington Beach
    Any updates with your MPG??
  6. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    No sure about anyone else's mileage, but I sought advice in private chat. It was my theory that my car, with a 5 year old 12v battery was left in the "on" mode for the duration that it was at the dealer (probably 8 hours). As a result, after picking up my car and driving for the next few days, my HV battery kept trying to make up for the lack of 12v storage on hand. So, my engine would turn on almost all the time. Even while driving on the freeway! I was going to replace my 12v at the 5 year mark anyway, so I did it. Mileage is back to 45 to 47 city and 49 to 50 highway. And the enging doesn't come on as much anymore. Yes, I did this without checking codes and the like. Private chat advice was spot on.
    Johnny Cakes and kenoarto like this.
  7. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    I'm not exactly sure you mean "lack of 12v storage" -- the 12v battery is basically just a load except when in the ACC position. In the READY position, the HV battery supplies all 12v needs.
    Your symptoms could possibly be explained by the HV battery depleting (causing ICE start) while attempting to recharge your nearly dead 12v battery.
    Montgomery likes this.
  8. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    I think Mr Burns (Montgomery) is saying that the hv bat is trying to recharge the 12v bat and that’s why ICE is staying on. In a situation that Mr Burns 12v bat is no longer able to hold charge, HV bat will continuously try to charge the 12v bat until it is full, but it can’t be charge full anymore and never reach full capacity.
    Johnny Cakes likes this.
  9. Montgomery
    2,254
    2,242
    Orange County, CA
    You said better than I could. That's basically what happened. Original battery could have lasted another year or two, but I was going to change it at 5 years anyway.
  10. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    They got another wrong - there's no dipstick for the transmission... dipsticks.
    ASRDogman likes this.
  11. GG707
    GG707 Member
    62
    26
    athens
    Excel
    Hey ,
    As it seems mine is not anymore in the list of this campaign! Although it seems similar... In my case as I understood this campaign reprogrammed power Management control ecu which seems to decide and drive gas motor and the mgs 1 and 2...
    so I've noticed the difference but unfortunately the screenshots of cdl and dcl values are in the old cellphone which is dead... So until I recover them(somehow) I remember but can't prove that these limits were higher if someone have the hybrid assistant and or torque and wish might check these values and send them before and after the campain... As I recall the limit was 28 to 30kw dcl and cdl that turned too low now... 22 kw... Which is similar the power loss I can notice during acceleration (it used to do 0-100kmh or 0-60mph in 10 seconds... Which does 12 now... Also the ice stays on longer starts sooner etc... the campaign did Anything that could in order to distress the hv bat and the inverter (at least the dc bat part with the capacitors) of course it still drivable and during normal operations there is not noticable change... But if I want to overtake an other car in a steep hill I can surely notice the difference... so as ChapmanF suggest if there is someone that can document the values for future reference then is welcomed :)
  12. ChapmanF
    18,889
    It would certainly be good to have more such data. As I understand it, both of those limits are dynamically calculated by the Battery ECU based on other factors, so apples-to-apples comparisons could still be difficult even with some readings of just those limits. But growing the set of data we have is never a bad thing.
  13. Freeze Time
    Freeze Time Member
    161
    50
    Huntington Beach
    On my drive home, I went to check my MPG and the damn low key battery came on instead so I have no idea what my MPG was. Is there some quick way to turn it off so I can see the info? I hadn't driven the car in 34 days so I should have taken the battery out of the key fob. I guess it constantly drains it even if it's not in use. Lesson learned.
