Received scan P0A80 yet display shows full charge (Green)
Discussion in 'Gen 2 Prius Technical Discussion' started by bill d, Apr 28, 2015.
  1. bill d
    bill d New Member
    Is it possible to get a P0A80 scan and yet have the display show full charge? The car only runs on the ICE and the hybrid batteries do not appear to be helping. What other components could cause this? Fuse? Computer(s)? Circuit Breaker(s)? Any suggestions would be appreciated. TX
    49,437
    how many miles on her?
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,220
    Madison, Wisconsin
    Is the big red triangle lit as well?
    Is the fan in back running constantly?
    Yes the battery can show full green but not working properly.
  4. Patrick Wong
    18,200
    6,472
    Yes. In fact if you drive the car you'll probably see the state of charge gauge fluctuate wildly between 8 green bars and 1 pink bar. That is indicative the traction battery needs to be replaced as suggested by DTC P0A80.
  5. bill d
    bill d New Member
  6. bill d
    bill d New Member
    Red triangle and check motor light; fan working
  7. bill d
    bill d New Member
    Thnaks
  8. bill d
    bill d New Member
    What is the chance that Toyota will give some consideration to the facts that the car has just under 31,000 miles and is just over the 8 year warranty? If so, how do I go about it?
  9. bisco
    49,437
    sounds like death from under use. there's a toyota phone number in the warranty booklet. i think there's a very good chance they will cover at least some of the cost. especially if you're the original owner with a complete service record. all the best!(y)
  10. bill d
    bill d New Member
    Thanks-worth a try.
