Recently purchased 02 prius, oil change??
Discussion in 'Generation 1 Prius Discussion' started by xtremebowhunter, Jan 29, 2012.
  1. xtremebowhunter
    xtremebowhunter New Member
    Massachusetts
    2002 Prius
    I recently purchased a 02 Prius. I do all my oil changing. I know it takes 3.9 Qt of 5w 30 oil. My question is how often should it be changed? I usually change my vehicles every 3000, but the owner's manual doesn't state how often. Thanks
  2. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    I use Mobile1 and go 7500 to 10,000 between changes. The Atkinson cycle engine doesn't work as hard as a normal car so synthetic oil lasts a long time.
    It's very important not to overfill the Prius engine oil above the fill line. Put in 3.6Q, then check level on a flat surface (like a gas station pad). Manually top up if necessary.
    Even if you only change your oil once a year, you should still check it every 3rd or 4th time you buy gas....keep on eye on the level / dirtiness.
