Recharge household batteries?
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, Aug 3, 2024.
  1. fuzzy1
    10,631
    Your pictured AAA Energizer Ultimate Lithium claims a shelf life up to 20 years, which works out to a self discharge rate of under 0.4%/month.
  2. ETC(SS)
    7,397
    Mine didn't last 20 years
    It didn't last 20 MONTHS - but it wasn't in storage.
    The Romeo 7 doesn't have shake-awake but at my settings the AAA has a 50k hour energy budget (5.7 years.)
    FORTUNATELY I have a calendar reminder to replace the cell at 36 months and I had the "installed" date on the sight.
    I also have the ability to swap put the battery twice (depending on ROI for a lithium replacement versus an alkaline) without re-zeroing the optic.
    Again.
    Sample size = 1.
  3. fuzzy1
    10,631
    Many of today's devices are never really Off, just sleeping. Their sleep currents vary enormously.
    Those Energizer Lithiums don't contain any more mAhs than their alkaline stablemates, but do maintain a significantly higher output voltage over their operating life. I can easily imagine cases where that higher voltage produces a considerably higher current draw (more than would happen with constant-R), greatly reducing battery operating hours. And a few items are simply incompatible with these lithium voltages. Merely inserting the batteries destroyed one device I had. No smoke, it just quit working, permanently.
    Without detailed knowledge of the internals, it can be difficult to predict the results.
  4. ETC(SS)
    7,397
    Concur.
    I reread the manual Romeo 7s) that came with the sight and discovered that the sight DOES use a 'shake awake' to achieve the 50,000 hour rating, but as you pointed out very few electronic devices are ever truly asleep and it takes very little motion to wake up a gun sight.
    The Lithium was the OEM battery and Sig put it in the sight for a reason - maybe because it's a green LED instead of a red one.
    Like Kermit says.....It's not easy being green.
    Lower wavelength.
    More energy for the same light in the LED.
    The OEM light lasted < 24 months, real world.
    My intentions are to replace it with a like unit and check for function more regularly.
    Everybody recycles batteries these days (or they SHOULD!)
  5. fuzzy1
    10,631
    That would certainly be a prima facie indicator that this device is compatible with lithiums. Lithium disulfides, that is, not lithium-ion.
  6. ETC(SS)
    7,397
    Yep.
    A bit off the OP - buuuuut that's PC
