Recharging the A/C
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ozymandias, Jun 8, 2008.
  1. ozymandias
    ozymandias Junior Member
    83
    Virginia
    Thanks for the advice guys. I remember reading that the ND-11 oil is really hard to find and is really expensive, so some shops use PAG 120 oil. Is this ok?
    I don't have a way to test the high pressure side. I think at this point, instead of spending money on more equipment it's better if I find a shop to fix it at a reasonable price. That will be a challenge around here. :pray:
  2. richard schumacher
    7,683
    1,066
    United States
    Patsparks had the correct advice and offered it first. Don't be offended by his straightforward Aussie idioms.
  3. Patrick Wong
    18,210
    6,517
    I really think that a Toyota dealer is your best bet for this service. Since the air conditioner compressor runs on high voltage AC, the insulation properties of the oil are paramount.
    From the 2005 repair manual, p. 55-2:
    "NOTICE:
     For the electric inverter compressor, use the NDOIL11.
     Electrical insulation performance may decrease significantly
    if even a small amount of oil other than NDOIL11
    is used (or enters) in the refrigeration cycle,​
    causing the DTC to be output.
     If other oil is accidentally used and a DTC is output,
    collect the compressor oil in the compressor and replace
    it with ND-OIL11 to increase the ND-OIL11 ratio​
    amount.
     Replace the main components (evaporator, condenser,
    and compressor) if a large amount of oil other than
    ND-OIL1 1 enters the system. Failing to do so may
    cause electrical insulation performance to remain
    low, causing the DTC to be output."
    Fern1461 and olerox like this.
  4. ozymandias
    83
    Virginia
    He didn't offer any "constructive" advice other than "just get it fixed", which really didn't answer any of my questions. The name calling wasn't very constructive either. I appreciate you standing up for him though.
  5. ozymandias
    83
    Virginia
    Thanks...I need to find a dealer in the area which doesn't charge $100 / hour and which also can re-use as much oil as possible.
  6. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    $90/hour is pretty common for labor rates nowadays.
    the oil... you're probably gonna have to just suck it up and buy some.
    sorry, it sucks, i know. does that estimate include fixing the leak?
  7. ozymandias
    83
    Virginia
    The estimate was to just fix the leak, I think. I don't think they had included the cost of the oil in there.
    This is a pretty expensive way learn and make sure the A/C works properly when buying a used car! :) It's pretty hard when you buy a car in February though.
  8. galaxee
    9,810
    471
    MD
    they should include the cost of restoring your system to full capacity after fixing a leak. if not, something's fishy.
    at least it's a lesson you'll only have to learn once ;)
  9. ivanbg
    ivanbg Junior Member
    Alexandria VA
  10. prius4ed
    prius4ed Member
    120
    Irvine, CA
    Recharging the A/C - correct low side pressure?
    A link somewhere on this forum leads to the 2004 Prius factory manual "Preliminary Release (RM1075U) which states (p. 55-13) the system takes 15.9 oz give or take 1.1 oz. It also says to fill until bubbles disappear and from there add 100g (3.53oz) freon. About half way while adding the 100g, the high side pressure will plateau and stop rising. I'm interpreting this to mean the proper way to know is to add the 100g after bubbles disappear.
    I'm still trying to figure out if you're allowed to evacuate a Prius AC system using an oil vac pump. Will it contaminate the Prius system?
  11. EllaGuru
    EllaGuru Junior Member
    London England
    Is there a thread anywhere on this site (hopefully including photos) which would help me make a visual inspection of the A/C components of my 2004 T4?
    (It hasn't been blowing cold air for several months now - not that you need a great deal of cold air here in the UK ...)
  12. JohnPV
    JohnPV Junior Member
    I took the '05 Prius in to get the A/C fixed at 37K ,need a condenser @ $820.0 . Took it in yesterday to get it fixed again @ 105K , need a Suction line? and a Evaporator ? @ 900.00 . I don't know but it sounds like a big rip off to me . Any thoughts on the cost of repairs .
  13. Patrick Wong
    18,210
    6,517
    Yes, Prius post-warranty repairs are quite expensive especially if you must rely on your local Toyota dealer.
  14. Mendel Leisk
    42,345
    Just to comment on the OP's description:
    This sounds like normal display in the sight glass. I recollect from shop manuals for previous Hondas we've owned: you should be seeing sporadic bubbles while the compressor is running, then a flurry of bubbles as it shuts down.
    He might be making assumptions and applying fixes where there actually is nothing wrong. And: if there is in fact a leak, it would be better to get it fixed properly. I would assume even the new stuff is not that good for the atmosphere.
  15. Holmz
    Holmz New Member
    Antipodies
    Well this is my first post here.
    I did see that there were some people that got a lot of "X thanks in Y threads", so I am pretty hopeful...
    So here goes:
    I am looking at getting a used/second-hand the Prius compressor. Does any one know the details of these units?
    I read that the insulating oil is needed because of high voltage A/C, so there has to be an inverter in there.
    1) Is the inverter part of the A/C system or general thing for the motor that drives he wheels.
    2) Interested in specs for the compressor... (the volts, amps, and frequency); and any other details that one needs to wire one of these to another car. I hear that they are variable speed, so I am assuming that the speed gets modulated based upon what the temperature of the evaporator section is at.
    3) Does anyone know if the compressor and evaporator ( or what ever it is called in a car) is pretty standard... i.e. could I use pretty much any car evaporator assuming that it is cleaned out?
  16. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Take a look at:
    http://www.autoshop101.com/forms/Hybrid06.pdf
    Otherwise, it is a typical TXV-type system. A small car set of condenser, receiver, expansion valve, and evaporator should just work. If you can get your hands on a Prius-specific condenser and evaporator core, that would be better, to know how much oil (ND-11 or equiv) and refrigerant to use. Don't bother trying to pull other Prius components to control it, as the A/C amplifier uses sensor inputs to send power requests over the CAN bus to the HV ECU, which then sends power from the inverter to the compressor. It is variable speed, so you could probably control it with a 3 phase Variac. Nominal voltage is 201.6VAC. Know where that comes from? It is the nominal voltage of the HV battery, just have to flip the DC to AC. That to me implies that the voltage can go higher or lower, probably quite a bit lower in the steady state. If I remember correctly, power draw is of order 1 kW. Good luck.
    Fern1461 likes this.
  17. Holmz
    Holmz New Member
    Antipodies
    Seilerts - thanks!
    My plan is to get the whole of the Prius system.
    Compressor evaporator and condenser.
    The get hoses to fit it up.
    Will probably set it up on the bench and work out a controller for it. DC-AC voltage using a 4 position switch (off, low, med, and high).
    More below in red
    Thanks again - this is helpful!
  18. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    I don't know if it is frequency or voltage, but I do know that it is not the same bus as the drive motors. It is in a separate part of the inverter. You'll have to tell us the whole story when you figure it out :)
  19. Holmz
    Holmz New Member
    Antipodies
    I guess I will need the male and female connector where the power cable goes to the motor and then measure the voltage and frequency in-situ.
    Now to sort out where I get the connectors...
    Either a bad/used compressor and power cable and cannibalise them for connectors.
  20. Wilsid
    Wilsid Junior Member
    91
    I bought the nd-11 oil at napa for $9.95 3 oz. I put that in and I put 134a in to
    35 lbs and stoped, ran air on max cold. You don't need any certification on
    your own stuff.
