Recommend Scan Tool for PC that can display high voltage battery module voltages
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by johnjamis, Nov 19, 2012.
  1. johnjamis
    johnjamis Junior Member
    78
    KY
    I see lots of scan tools that will hook up to my PC via usb port, but I can not determine if they will display High Voltage battery individual module voltages. Can someone reccomend a good scan tool that will display these voltages on my PC?
    I see this Scan Tool 423001 Elmscan 5 Compact OBD-II Scan Tool and OBDwiz diagnostic software for $23 on Amazon. Will this display HV battery module voltages?
    I do not need the bluetooth wireless type. Thanks, John
  2. John H
    John H Senior Member
    2,208
    556
    I use the cheap bluetooth odbii adapter and torque on an android phone loaded with the custom PIDs for the Prius that usbseawolf assembled together.
  3. johnjamis
    78
    KY
    I don't need a wireless setup unless it is the only way or cheapest way to get the voltages. Which cheap obdii adapter are you using?
    I do have an android phone(Motorola Milestone), but I am not sure I can figure out how to set it up with the obdii adapter. Thanks, John
  4. John H
    2,208
    556
    johnjamis likes this.
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,972
    Fort Lee, NJ
    If you have an Android phone or tablet, $18 for a bluetooth adapter is a no brainer.
    Here is a link to the custom PID thread.
  6. johnjamis
    78
    KY
    Thanks for the recomendation. I read the thread above but it is so technical and lengthy that I could not come away with what to buy. I will try the ELM327 diagnostics USB Cable based on what your outcome was. Could you monitor the HV battery module voltages with this setup? Thanks, John
  7. nh7o
    nh7o Off grid since 1980
    1,686
    326
    Hawaii
    Look for "mini vci" on eBay. It works for GenII.
  8. johnjamis
    78
    KY
    I think this "mini vci techstream 7.10 vehicle diagnostic device" may be what I need. Can you verify that you can read the HV battery module voltages using this mini vci device hooked up to your PC? If so, the price seems reasonable at $26 on ebay. Do I need additional software to display the HV battery module voltages using this device? Thanks, John
  9. nh7o
    1,686
    326
    Hawaii
    No.
  10. johnjamis
    78
    KY
    Thanks for the help. I will get the mini vci. John
Loading...
