Recommendation for new accessory pure sine wave inverter
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Another, Sep 22, 2021.
  1. C Wagner
    C Wagner Member
    183
    60
    Boston
    Great - have you hooked it up to a transfer switch without issues?
  2. Simbaboy
    Simbaboy Active Member
    134
    112
    Mid-Michigan
    Sorry, I dont know what you mean.
    I have used the inverter with a small 700 W microwave and no issues.
    Simba
  3. ChapmanF
    18,187
    Thanks, that answers the first question. Can you describe your measurement setup precisely? What do you measure if you bond the neutral and ground together?
    (If you are concerned about such a test letting the smoke out, you could begin by bonding the two through something like a 4.7 kΩ 1W resistor and measure what actual current flows. I expect you will find it to be negligible, and can then proceed to checking with the neutral and ground bonded. Or if you don't like large leaps of faith, you could repeat the test with one or two smaller resistance values and plot the measured current.)
  4. C Wagner
    C Wagner Member
    183
    60
    Boston
    Transfer switches are for inverters (compatible ones, anyway, floating ground) that plug into house wiring, such as for a furnace on its own circuit.
