Recommendation for New Hybrid Battery Vendor Please?
Discussion in 'Gen 3 Prius Technical Discussion' started by Joe-G, Apr 3, 2023.
  1. Mr. F
    Mr. F Active Member
    388
    257
    Washington
    If the corrosion was on the surface of the bus bars directly in contact with the nuts, cleaning will help. The nuts should all torqued down to spec (48 inch-pounds) during reassembly. However, if those areas were clean, the problem may lie elsewhere.
    If going the aftermarket route, I'd also look into newpriusbatteries.com.
    #21 Mr. F, Apr 16, 2023
  2. Joe-G
    Joe-G Member
    243
    99
    Ft. Lauderdale, FL
    The corrosion was on the nuts and the bars underneath. They are tidy and clean now!
  3. sambojoho
    sambojoho Proud conservative
    92
    23
    Ohio
    I See on Rock Auto, Dorman sells the batteries packs for $2150 +$500 core. Has anyone used these? They claim some upgrades.
  4. Eddie25
    Eddie25 Active Member
    497
    209
    MI
    I suspect the upgrades are going to be like the buss bar and stuff, not the modules. I'm also assuming they are reman units and that's pretty much the price you pay for a brand new battery at a dealership*, so I don't see the point.
    If I'm wrong and those are new modules then sure it seems like a fair deal.
    *I'm still skeptical that you can purchase one from a dealer with no diag/install charge, but I've been told it's possible.
  5. bisco
    51,941
    dorman has been poor quality up to now, idk about upgrades. if they upgraded to new cells it might be worth it, but most can get an oem in the 2k range
  6. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I bought a refurbished HV battery from the originator or the refurbishing process in spring, 2011 in Sanford NC and had a great experience. He later sold the business to Dorman, but they had some early quality control issues. I haven't heard any feedback on their HV batteries recently.
    JeffD
  7. mikeflores2000
    mikeflores2000 Junior Member
    52
    23
    Merced, CA
    At least in California your Toyota Hybrid battery is covered under warranty for 150,000 miles or 10 years whichever comes first.
