Recommendation OBD device
Discussion in 'Gen 2 Prius Main Forum' started by Ernie stires, Mar 5, 2024.
  1. Ernie stires
    Ernie stires Member
    107
    30
    Colorado
    I’m thinking of under $200 scanner that I can use to view and clear codes like brakes. My Techstream copy is acting up. What are you using? (I have an Obd dongle and dr Prius, I’m looking at a full device.)
    TIA
  2. Brian1954
    Brian1954 Senior Member
    2,493
    999
    South Central PA, USA
    Ernie stires likes this.
  3. Ernie stires
    Ernie stires Member
    107
    30
    Colorado
    Thanks! I have tried several of these apps, yes. I now thinking of buying a full fledged 2 way scanner but don’t want to spend more than $200 or so.
  4. turbo5spd-prius
    turbo5spd-prius Junior Member
    71
    United States
    Are you using TechStream on an old laptop? If you're not using a VM for TS, consider this.
  5. Ernie stires
    Ernie stires Member
    107
    30
    Colorado
    I had TS on an older laptop, correct.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,102
    2,005
    NJ-USA
    The ThinkDiag IS a "full fledged 2 way scanner" - it appears to have all the same functions as Techstream.
    The only problem I see with it is that you need to pay an annual subscription every 12 months to keep it functional.
