Recommendation on Best 12V battery replacement
Discussion in 'Gen 3 Prius Technical Discussion' started by Direwulff, Aug 1, 2019.
  1. bisco
    52,861
    it won't be a problem unless you are unfortunate enough to be rear ended. even then, unlikely.
    its a safety measure, and certainly one that an oem cannot ignore
  2. Mendel Leisk
    42,352
    Pep Boys seems to draw a blank for Prius batteries right now, which is odd. Maybe phone them. Up here, Canadian tire has one readily available (if I enter 2012 Toyota Prius):
    "MotoMaster" is their house brand, not sure who actually makes it. Next time around I might give them a try. We got the motomaster replacement battery for our son's Civic, and it looked to be identical to the Honda battery, and worked out fine.
    BartZ likes this.
  3. Aegean
    Aegean Active Member
    464
    209
    Alexandria VA
    Robert Holt, BartZ and tvpierce like this.
  4. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
  5. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    Bummer! I don't need one! The original owner replaced it a month or so before I bought the car.
    I should be good for at least 4 or more years.
  6. JROLD
    JROLD Junior Member
    S.E WI
    My suggestion would be to do a search on this site about using a mobility AGM battery in place of the AGM unit supplied by Toyota. I have a 2010 Prius and just picked up exactly that, a AGM sealed 12 volt 55 amp mobility battery that cost me $80. Although the Pep boys suggestion is a great one, unfortunately for me there are none in my area.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    If I had a penny for every time I say that to myself when reading a new post.
  8. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I bought a pair of SAE to JIS adapters. I’m going to put a conventional 51 series battery in mine when the time comes. Rural King in my area has a 51AGM for 110. And I have the option of going back to the JIS battery if the need arises.
  9. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    I just had my 2010 original Prius battery tested at Walmart.It tested good. Will take it back next year to test again. this is the 5th year i have had it tested!
    My local tire-man dealer Toledo,Oh told me he could install a Crown agm batt. made in Fremont Ohio for 155$ with a 60 mo. warranty. If it ever fails.
  10. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    I don't see a vent connection in the picture -- so the expelled hydrogen (and maybe other vapors) will end up in the cabin.
  11. Aegean
    464
    209
    Alexandria VA
    There is a vent on the Bosch AGM.battery and it is also reversible on both sides left and right.
  12. KevininFl
    KevininFl Junior Member
    62
    16
    Fort Myers Fl.
  13. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    If it is a true AGM type, there will not BE any gasses of other vapors to BE expelled.
    Most AGM batteries do not even HAVE a connection for a vent hose.
  14. CR94
    CR94 Senior Member
    2,831
    1,243
    Northwestern S.C.
    That's normally true, but there could be gasses emitted under certain abnormal conditions.
    Some AGM batteries that are not originally equipped with a vent connector (my $65 U1, for example) can easily be modified to have one.
  15. flyboy09
    flyboy09 Junior Member
    Seymour Tennessee
  16. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
  17. Mendel Leisk
    42,352
    Regular size posts?
  18. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    It has the SAE posts. But I have a positive and negative JIS to SAE adapter, from http://www.batterymart.com. Their item numbers 850350 and 850250. $13 and change shipped in 3 days.
  19. BartZ
    BartZ Junior Member
    So, last week, I went to O'Reillys to check my battery as I assumed, based on my toys, that my battery is bad since every so often the voltage drops to below 12V. They have a digital device to test the battery and it showed that the battery is bad, the polite guy from my local O'Reilly in Camarillo, CA tried to find what is the cranking amps on the stock battery since it looked small to him, so we have tested it at 600 and then at 550 since we couldn't read the stock battery info, both times the tester showed, that the battery was bad. I asked to quote me a new battery to see what they have... Back in the store, while he was looking at new batteries starting at $194 he has also noticed that stock battery has only about 315 or 350 cranking power. We went back to the car and tested it at that level, voilla! The battery is good! I'm posting this just in case anyone else finds themselves in similar situation starring at the store battery tester screen showing "bad battery" with no explanation...
    Robert Holt likes this.
  20. Mendel Leisk
    42,352
    Yeah the stock battery on ours had no indication of the Cold Cranking Amps. A LOT of searching of Yuasa website later, I came to an iffy conclusion it was around 325'ish. A decent electronic load tester would display the as-tested CCA. A new battery, or one still in good shape, will have CCA well above the spec. If it's at the spec, or a bit lower, probably time for replacement.
    Is that the original battery?
