Recommendation on Best 12V battery replacement
Discussion in 'Gen 3 Prius Technical Discussion' started by Direwulff, Aug 1, 2019.
  1. BartZ
    BartZ Junior Member
    I believe so, I've got the car with 44k miles in 2016 and haven't change it since.
  2. Mendel Leisk
    42,347
    You can check for yourself with something like Solar BA9 (around $45 US). 6 years is a good run though.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    THIS is a potential problem with automatic "idiot proof" battery testers.
    In many newer vehicles, hybrids in particular, the VOLTAGE is more important than being able to deliver big amperage currents.
    If the tester has other test "modes", those tests need to be done too.......and several times in a row too.,
  4. Mendel Leisk
    42,347
    I'm not sure that voltage is more important, than the CCA measure. A battery in a certain state of viability can have widely varying voltage. One extreme being after a door's been left ajar overnight. The other when it's freshly charged, sporting a "surface charge". But it's viability is roughly the same.
    Testing it's CCA tests it's "legs"? Does that make any sense?
    Too, I think it's conflation, to say that CCA doesn't matter, because a Prius doesn't use the battery for cranking.
    I use a Solar BA5 tester. You enter the rated CCA for the battery, and the battery type (conventional, AGM, spiral coil AGM, etc), and it gives a verdict, either "OK", "OK but in need of recharge", or "Fail". It also gives a tested CCA reading every time, and that doesn't vary if you enter a higher/lower rated CCA value.
  5. sam spade 2
    7,035
    2,804
    2017 Prius c
    I did not say that CCA doesn't matter (at all).
    I said that voltage is more important, under a moderate load.
    Although not really common, an old battery can show very low voltage under light to moderate load but respond to a HEAVY load by putting out a decent spike of current which can fool some tests.
    The only tester I trust is one with two meters; one showing the voltage and another showing the test current.
    That way, you can SEE the voltage before, during and after the test.
  6. CR94
    CR94 Senior Member
    2,830
    1,243
    Northwestern S.C.
    Group 51, or 51R? One has terminal locations switched. Otherwise, should work ok with the terminal adapters.
  7. tallprius
    tallprius Member
    62
    29
    texas
    Premium w/ Solar Cells
    IF you are ok with a smaller battery a Mazda Miata AGM battery fits well it however has standard size posts. The OPTiMA battery was easier to hook up.
  8. sorrywereclosed
    sorrywereclosed Junior Member
    SF
    Has anyone use the Miata battery?
  9. bisco
    52,855
    i think so
