Recommendations for headlight bulbs?
Discussion in 'Gen 3 Prius Technical Discussion' started by Scottyboy24, Sep 10, 2017.
  1. Scottyboy24
    Scottyboy24 Junior Member
    33
    Pensacola, Fl.
    Just found out about the ongoing prob on the 2011 prius with the driver side headlight wiring prematurely blowing the bulb. I am on my 4th set since the orig. ones blew.
    I decided to try some LED's since I was hearing the higher voltage requirement for the aftermarket bulbs such as the best that Sylvania makes (SilverStar Ultra's@$51.00 a pop!) was the reason they were only lasting me 6-9mths! (and was not that impressive on light output anyway)
    I forget exactly but the charge was upwards of 200-300 to have this problem fixed by Toyota! (Toyota made the mistake but we have to pay for it!) This of course should have been a recall and fixed!
    Anyway, I do not like the LED's I got as they are just not lighting the road up enough,PLUS when I turn them on I loose every radio station, so wanted to see if anyone else has been going thru this and might know what low watt bulb out there may light things up more than most people know about?
    Also a BIG question I have is has anyone installed a HID kit on a Prius? But I am guessing that will only cause problems due to it already having a wattage problem, right?
    But as for the HID's if anyone else has fixed the wiring prob, and love the amount of light they put out, I would probably go with the HID's because I have poor night vision and want to light up the road as much as I can get away with!
    I read how to fix them some where on line but forgot where i seen it at the time, but not sure if i can pull it off by myself? Sounded pretty complicated. Anyone done this fix yet?
    The LED's are terrible especially after I switch to the factory brights!(that I have never had to change)
    When I go from the brights to the low beams, it's like I can barely see the road!
    Anyway, any help at all here will be greatly appreciated. Thx!
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    I have 35w AC ballast HIDs on our 2011 and they're great. 4300K color temp.
  3. Scottyboy24
    33
    Pensacola, Fl.
    Thx so much for that! So did you know about the wiring problem or have any problem with bulbs prematurely blowing on the driverside? What yr make is ur prius?
  4. Scottyboy24
    33
    Pensacola, Fl.
    Sorry you already told me the yr make. duh -- but anyway I am worried about that manufactures wiring problem ruining my HID kit if i get one? Thx again!
  5. AzWxGuy
    AzWxGuy Weather Guy
    1,078
    558
    Tucson, AZ
    2021 Prius
    I have a 2011 Model 3 and this is the first I've heard about headlight problems as you describe. My model has the halogen projector lamps for low beam. At nearly 150K miles the lamp color temperature is turning a bit yellow, but still more than adequately illuminates the road. I do remember reading a thread about someone replacing bulbs and somehow not getting the lamp properly seated in the housing which affected the illumination pattern. I had HID on my 2008 and really liked them, until I had to replace a bulb. $$
  6. xliderider
    8,140
    3,280
    Honolulu, HI
    I'm using a dual relay HID harness like this DDM HID Xenon Conversion Kit Dual Relay Harness Dual In Dual Out, Fit All Bulbs | eBay which bypasses the factory lowbeam wiring for supplying the power to the HID ballasts. The factory lowbeam wiring circuit is only used to activate the relays in the harness, which operates at very low current levels. So it mitigates the voltage problem, if the have it, because the relays can operate in the ranges that are encountered in the Prius electrical system.
    I have a 2011 level 3.
  7. ChapmanF
    18,964
    The real explanation is nearly the opposite: all those highly touted "best bulbs we make!!1!" bulbs have, in effect, a lower voltage requirement than a bog-standard H11. They have a filament designed to make the tradeoff aggressively for light output at the expense of longevity (which is what you get by building, effectively, a slightly lower voltage filament). Combine that with the unexpectedly higher voltage arriving at the bulb in the 2010 or '11 Prius, and you get a super short lifetime.
    If you don't swap out for wholly different technology, or get the wiring modification done, your best bulbs will be the bog-standard H11 ones. In the auto parts stores they are usually on the lowest level of hooks down by your ankles where management hopes you won't see them, and they sell for a fraction of the price of "best bulbs we make!!1!"
    Mine are still going strong at 17 months ...
    -Chap
    frodoz737 likes this.
  8. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    I upgraded my 2011 Prius Three to OPT7 55W AC Bolt series, 5000K color. They run off the factory headlight wiring just fine without using a relay. The factory voltage issue isn't a problem because a little bit higher voltage/lower resistance going to the ballast won't hurt anything. It is a fantastic conversion kit, in my opinion. On both sides of the engine compartment, on the inside of the fender are plastic shields. Be careful to squeeze the clips with needle nose pliers to remove the shields, and the backside of the shields make a great place to mount the ballasts.
    Just stay away from the cheap/generic/Chinese kits off Ebay and go with a good name conversion kit. I also replaced my fog lights with 6000K LEDS and in the turn signal housing I have switchback LEDS that are connected to the parking lights - white DRLs when the parking lights are on and flash yellow on the turn signal. I just leave the switch in the parking lights position all the time.
