Recommended place for GenII 60k Service in Portland OR
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by darrenhyee, May 15, 2012.
  1. darrenhyee
    darrenhyee New Member
    Portland, OR
    Hi
    New to the forum - i'm due for my 60k service on my 2006 Prius. 600 bucks at broadway toyota! i've been taking my Prius to broadway up till now - no complaints tho not sure if i'm overpaying for what i'm getting. Budget is getting tighter so i'm wondering if there are cheaper, reliable options
  2. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
    http://www.toyota.com/t3Portal/docu...MS0012/pdf/06omsour/2006/schedmai/61w1smt.pdf
    Page 12 of the PDF, edited by me
    q Replace engine oil and oil filter
    q Rotate tires
    q Replace cabin air filter
    q Replace engine air filter
    q Inspect the following:
    __ Automatic transmission fluid
    __ Ball joints and dust covers
    __ Brake lines and hoses
    __ Brake linings/drums and brake pads/discs
    __ Differential oil
    __ Drive belts
    __ Drive shaft boots
    __ Engine and inverter coolant
    __ Engine valve clearance
    __ Exhaust pipes and mountings
    __ Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
    __ Fuel tank cap gasket
    __ Radiator, condenser
    __ Steering gear box
    __ Steering linkage and boots
    Additional Maintenance Items for Special Operating Conditions:
    Driving While Towing
    q Replace automatic transmission fluid
    q Replace differential oil
    q Tighten nuts and bolts on chassis
    Driving in Desert or On Dirt Roads
    I would replace the Automatic Transmission Fluid even if not towing, if it was me, unless you already have.
    The ATF 'should be' $100 and all the rest another $100.
  3. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
  4. jabecker
    jabecker driver of Prii since 2005
    448
    78
    Portland, Oregon
    I always took my 2005 to Ron Tonkin. I don't remember how much my 60K service was, but I'm pretty sure it was less than $600. You might want to give them a call and ask.
  5. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    Jimbo's list is what I've heard from my local service advisor: you don't *need* to change anything but the oil, oil filter and maybe the air filters until you've hit 100k.
    If you *want* to be extra cautious, you can change the transaxle fluid while you're at it.
    But if you believe your car's doing fine, you haven't driven it very hard, or in severe conditions, you should be okay with just an oil / filter change and tire rotation. You can knock the dust out of the air filter yourself for free. :)
    If you're paying any more than $200, you're getting ripped off. Shop around. Maybe find an independent mechanic that gets good reviews?
