Recommended Tire Pressure
Discussion in 'Gen 3 Prius Fuel Economy' started by Big Steve, Jun 2, 2012.
  1. walter Lee
    1,126
    376
    Maryland
    Tire tech is getting sooo much more complex. ..:confused:
  2. Insight-I Owner
    Insight-I Owner 2006 Insight-I MT + 2011 Prius
    505
    100
    Essex, CT
    Scrounging around the Goodyear website, I found a complete list of Assurance Fuel Max sizes and specs here:
    Assurance® Fuel Max® Tires | Goodyear Tires
    click on the link "View Tire Sizes and Specifications" halfway down the left side.
    The Prius size P195/65R15 seems to be the only one that comes in two different specs: S and R. Misleading. I'm perfectly happy with my S's. Interestingly the S version costs $6 more than the R version on Tire Rack. Warranties are the same: 65,000 miles. R is rated at 51psi, S at 44psi.
  3. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    They are H & S not H & R, but you knew that:D
  4. Insight-I Owner
    505
    100
    Essex, CT
    Sorry! My brain did but my fingers didn't get the message.
  5. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Funny part is, I should have said "H & S not R & S." That nerve path deficiency between fingers and brain is widespread.:LOL:
  6. alekska
    alekska Active Member
    435
    138
    Atl
    You were not all that mistaken.... In simplified theoretical physics the area does not matter, but in real life situation is more complex. In winter slush lower area may have an advantage as tire would be able to push through snow and reach solid pavement .
    In summer larger tires / higher area would probably be better in terms of better friction .
    Alex
  7. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    I call it "finger dyslexia"
