Reconditioned Battery/5 year warranty/1500 dollars
Discussion in 'Gen 2 Prius Main Forum' started by Scott56, Jun 18, 2017.
  1. Will Stewart
    Will Stewart Junior Member
    45
    Northern Virginia
    2014 Prius Plug-in
    It undoubtedly depends on a number of factors, such as;
    - How many more years (and miles) will the car actually be used? We are estimating on another 2 years for our 2005 Prius, if it makes it that long without a major repair required.
    - Knowledge of the reconditioner. There are a number of shade tree "We fix hybrid batteries!" yokels on Craigslist who offer no real warranty, work out of their garage (after you finally are able to track down where they are), and give no process details or cell data whatsoever on the 'reconditioned' battery array. As an electro-mechanical engineer, I'm satisfied with what I've heard in discussions with Tim.
    - Inventory management. A sizeable operation will be taking in a number of batteries per week, much more able to assess and match workable cells to well-matched packs. The shade tree operator is going to rummage around through whatever they have laying around.
    - Staff. Tim's local installer was fast, efficient, exacting. He took about an hour for the entire replace and every single nut or fastener was carefully removed and replaced.
    So yes, if such an operation were not run intelligently, they likely would not end up making money, though one could say that for just about any business endeavor.
  2. Will Stewart
    45
    Northern Virginia
    2014 Prius Plug-in
    tvpierce, the first battery was installed two months ago.
    Prodigyplace likes this.
  3. Prodigyplace
    12,564
    11,779
    Central Virginia
    I am glad you are happy with that. I had a server replaced under support contract and the replacement failed in 2 months. They are now sending me a new replacement, acknowledging I should not need to replace it every two months.
    Personally, I would expect a replacement battery to last longer than 2 months. Since you bought your battery before November 1, 2017 it only has an 18 month full warranty that is then pro-rated out to 5 years, according to Green Bean's website.
  4. Fredsimm
    Fredsimm Active Member
    188
    117
    Tupelo MS
    "Unfounded grousing". That's such a nice way of putting it. I had to look it up. Thanks, I now have a new word for my vocabulary.
    grouse
    Verb
    gerund or present participle: grousing
    1. complain pettily; grumble.
      "she heard him grousing about his assistant"
      synonyms: grumble, complain, protest, whine, bleat, carp, cavil, make a fuss.
    SFO likes this.
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Just be careful because the noun has nothing to do with the verb. It's a little game bird.
    Will Stewart and Prodigyplace like this.
  6. Pat Lassonde
    Pat Lassonde New Member
    Clinton, IL
    I have been looking on here and you seem to know some stuff. So yesterday my husband was driving our 2007 Prius home, the warning triangle and slash through the body of car came on and car died. It restarted and he got home with it. The tow company asked us to move it to the street, I went out and started it and moved it, warnings still on. Then needed to move it a little farther forward and when I restarted it it sort of jumped and all of the warnings went out. Do you know if anyone else has had this happen or what it means?
  7. Prodigyplace
    12,564
    11,779
    Central Virginia
    The lights mean there are trouble codes to direct you where the car sees a problem.
  8. Pat Lassonde
    Clinton, IL
    OK, so what do I do? How do I get codes? I won't even look under the hood. Older cars I get this is way past what I want to deal with.
  9. Prodigyplace
    12,564
    11,779
    Central Virginia
    The dealer has software that can read the codes. Some dealers charge $100 just to read the codes. If you post the codes here, we cah advise you further.
    I just noticed that all the warning lights went out. Perhaps @Raytheeagle or @bisco have some ideas.
  10. Pat Lassonde
    Clinton, IL
    Will they see these posts? This is the first time I have been on here or any forum for that matter. Just thought someone may have experienced these things before.
  11. Prodigyplace
    12,564
    11,779
    Central Virginia
    I tagged them so they would get notified. Notice I put a "@" in front of their usernames.
  12. Pat Lassonde
    Clinton, IL
    Ok thanks.
  13. ericbecky
    ericbecky Hybrid Battery Hero
    4,440
    3,308
    Madison, Wisconsin
    Either you will need to buy tools to read the codes yourself (less than $75 plus some time configuring the software)
    Or you will have to get the codes read by a mechanic or auto parts store that has tools that can read the specialized Hybrid Codes.
    Some auto stores may read codes for free, but often they don't have quite the right tool for the job.
    I'd the car problem is not fixed the lights will likely come back. There are some basic things that may be helpful to narrow down the problems. For instance, having your 12v battery tested to make sure it is in good health. (replacement can be $250 or more.)
    If this problem drags on it may make sense to start a separate thread outlining the problem so we can discuss it more in depth.
    That way this thread stays on topic of discussing the 5 year warranty battery.
    SFO likes this.
  14. Pat Lassonde
    Clinton, IL
    I am forum challenged - how do I start a new thread. i tried and it said I had to include one person in the space above the title. What do i do there? maybe when my grandson gets home from school he can help me with this. I will try if you tell me how to do it.
  15. ericbecky
    4,440
    3,308
    Madison, Wisconsin
    Don't worry about it for now.
    As far as diagnosing your car.
    Basically we are guessing from a distance until somehow you can get the diagnostic error codes read.
  16. Pat Lassonde
    Clinton, IL
    OK, will work on that next. Thanks. Have to wait for someone to get here, hope I can get back to this page.
  17. bisco
    51,939
    pat,
    to start a new thread, go to the main forum page and scroll down to gen 2 maintenance and troubleshooting.
    click on that forum, and to the upper right of the threads, you will see 'post new thread'. click on it, create a header (sort description of the problem) and click 'create'. you will start getting responses, and can find the thread anytime by clicking on your avatar twice.
  18. red_prius
    red_prius New Member
    Charleston, SC
    To update my status - We did keep the Prius and had @TMR-JWAP install a 2011 battery in it this past Sunday. The price was right and after checking out many of his posts on the forum here and speaking with a few of the folks who he's helped out I was convinced. It was fun watching him install the new battery - I've done a bit of work on the prius already (original owner) and was honestly a bit surprised by how easy the battery was to replace. I think the 'attempting to fix this can kill you' stuff that I'd seen on the web had me scared. No such warnings when I replaced the control valve or touch screen :p.
    Anyway - I am really happy that there are so many options out there for folks who are having issues with their hybrid batteries and I am happy with the decision I made to keep the car and replace the battery. Hopefully it will last a long while!
    bisco, SFO, Will Stewart and 4 others like this.
  19. Green Bean Battery
    Green Bean Battery New Member
    Raleigh NC
    Thanks Will. We appreciate your business and your trust in us. While your battery failure is a rarity we ensure that any warranty issue gets priority and we promise to learn from each and every one. Thanks for the kind words, and happy new year.
  20. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Now that the Stupid Bowl is finally over can a date be worked out for Battery Bash 2018 :whistle:
    cas8747, Yaga1973 and Prodigyplace like this.
