reconditioning discharge voltage
Discussion in 'Gen 2 Prius Main Forum' started by PriusOwner428, Apr 14, 2022.
  1. PriusOwner428
    PriusOwner428 Junior Member
    85
    IL
    Reconditioning battery pack one module at a time using a EV-Peak CQ3. Current question is to what voltage level should the modules be discharged? I've seen a kinds of numbers out there. Some saying not to go below 5V and others saying to go down to 3V. Interested in what others that have done this process think and why. I know the Prolong says to take them do to 3V:
    First Discharge: 134V / 28 = 4.8V
    Second Discharge: 101V / 28 = 3.6V
    Third Discharge: 84V / 28 = 3.0V
  2. PriusCamper
    PriusCamper Senior Member
    13,452
    5,430
    Pacific Northwest, USA
    I like to go down to at least 1 volt on the third round and when I first learned in 2018 Hybrid Automotive was saying you need to go down to 0.06v but that takes so long I use 12v 50w & 20w light bulbs to speed it up. It comes down to stress testing versus how many modules do you want to ruin before you put that pack back in... Thermal camera helps alot at finding bad cells too.
    PriusOwner428 likes this.
  3. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
    Which thermal camera are you using?
  4. PriusCamper
    13,452
    5,430
    Cheapest one with largest sensor...
  5. PriusOwner428
    85
    IL
    Interesting. So Hybrid Auto/Prolong was saying 0.6V in 2018? I got that number from the Prolong website (Third Discharge: 84V / 28 = 3.0V). So in 4 years they drastically changed their recommendation. As far as ruining the modules, I assume if the modules were reasonably healthy they should be able to survive and improve from that deep plunge right? So what you're really doing is helping push those borderline "good" modules over the edge.
  6. PriusCamper
    13,452
    5,430
    Yeah... They raised that lowest number more than once. It's not easy selling a product like this to consumers who are going to yell at you if you kill their pack.
    The other aspect of this is that my buddy Joe in Oregon who has $30K in lab-grade battery rebuilding equipment with robust software never has to go below 6v in his three rounds of reconditioning and the reject modules he deems not good enough for the packs he rebuilds, but still good, are the ones I buy from him and they're always the strongest module in a pack I add them too.
    He thinks it's thoroughly amusing that he gets better results than us only going down to 6v and can't comprehend why we would waste so much time going so low and getting less favorable results.
  7. PriusOwner428
    85
    IL
    Well that's easy to understand. We don't have 30K in equipment & years of experience. We're out here rubbing two sticks together.
    Since I've gotten module 2 to finally hit above 5000 on discharge & 8000 on the charge twice in a roll, you think module 2 has finally been recovered, or is still screwed? Doing discharge to 6V right now.
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    When I did my pack, if a module didn't have good capacity on a discharge after cycling down to 6.0V, there was nothing to lose (except time) by going down to 5.0V or 4.0V. Either a module improved to at least 5500mAh where the others are, or it's junk.
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    You are misunderstanding how the prolong system works.
    You will NEVER see:
    It will never happen because that's not how it works.
  10. PriusOwner428
    85
    IL
    If I were using a Prolong to do the whole pack at once I would expect to be able to see:
    Since I'm using the CQ3 & doing each module individually I would expect to be able to see:
    First Discharge: 4.8V
    Second Discharge: 3.6V
    Third Discharge: 3.0V
    What is wrong with my thinking?
  11. TMR-JWAP
    6,404
    6,095
    Columbia, SC
  12. PriusOwner428
    85
    IL
    OK thanks. That was interesting and informative. Ironically my best move when I first got this pack might have been to simply have installed it in the car to see if it triggered any codes. It might have been well balanced especially since all the individual modules were within .02V of each other. Now I might have improved all individual modules but also increased the delta between them.
  13. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    If the modules are "good", a bit of voltage difference between them won't cause a problem. They'll even out as the car is used. I have a thread in here somewhere in which I purposely repaired a battery by replacing a failed module with a module reading about 0.5 volts lower than the others. Worked just fine. The important thing is that it's a good module.
  14. alftoy
    1,132
    519
    Thanks, but I would have thought you would have sourced a reasonably priced one. Possibly one less than $300, maybe one you found on ebay. $300 is certainly a no go for just measuring cell temp. Which one are you using or is it just your buddy in Bend using one?
    Since the cameras are infrared, why not an infrared laser thermometer for $30.
    SFO likes this.
  15. PriusOwner428
    85
    IL
    I guess that continues to be my problem. Figuring out what defines a good module. I thought a good module was one that when discharged would be at 5000mAh or higher & when charged could reach 7500 or better. Problem is even when I get those numbers, the next cycle could have them out of that range again. The whack-a-mole problem on an individual module level.
  16. alftoy
    1,132
    519
    Maybe load test each module to find good or bad module.
    Prolong Battery Module Load Tester User Guide | Hybrid Automotive
    Or make one yourself.
    #16 alftoy, Apr 16, 2022
  17. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    If your measurements are that inconsistent, there is something wrong with your setup or the equipment you're using.
  18. PriusCamper
    13,452
    5,430
    Yea, I always try the cheapest solution first... Problem is there's 168 cells in a Prius pack and it was a total fail pulling the trigger on a cheap laser thermometer 168 times every time you want to check the whole pack compared to a quick glance at cheap thermal camera that color codes the hottest cells.
    The one I currently have is the cheapest Seek Thermal that plugs into your phone and is a bit over $100 because we bought it used on ebay... The flir works way better because it allows you to blend an image sensor with a thermal sensor. Here's a picture of what I'm talking about. These bad modules tested out fine by every other measure. But clearly they're about to fail due to heating up:
    It's worth the money because there's lots of uses for these cameras if you're for example trying to make winter home heating more efficient, or sourcing an exhaust leak or optimizing cooling systems in your house, etc...
    #18 PriusCamper, Apr 16, 2022
    Albert Barbuto and alftoy like this.
