Reconditioning Experience with Hybrid Automotive's Prolong System
Discussion in 'Gen 2 Prius Main Forum' started by biglew8, May 16, 2017.
  1. biglew8
    biglew8 Active Member
    170
    114
    Seattle
    Hello everyone! I wanted to share my hybrid battery reconditioning experience with you. I purchased the Hybrid Automotive Prolong Deluxe Reconditioning Package. It has the Prolong charger and automated discharger.
    2005 Toyota Prius Base Model
    Start: Thursday 05/11/17 9:00pm
    Finish: Monday 05/15/17 6:30am
    1st cycle:
    • Charge and balance (Started at 225V; Ended at 241V): Thursday 9:00am - Friday 10:00am --> 13 hours.
    • Discharge to 134V: Friday 10:00am - 3:00pm --> 5 hours. IMG_1298.JPG IMG_1302.JPG IMG_1309.JPG IMG_1315.JPG
    2nd cycle:
    • Charge and balance (Started at 165V - Voltage went up a little after discharge was done. Normal per Hybrid Automotive; Ended at 237V): Friday 3:00pm - Saturday 7:30am --> 16 hours.
    • Discharge to 84V: Saturday 7:30am - 12:45pm --> 5 hours, 15 min. IMG_1324.JPG IMG_1335.JPG IMG_1336.JPG
    3rd cycle:
    • Charge and balance (Started at 170V - Voltage went up since I didn't check earlier to see if it was done; Ended at 238V): Saturday 12:45pm - Sunday 6:30am --> 17 hours, 45 min.
    • Discharge to 17V: Sunday 6:30am - 11:25am --> 4 hours, 55 min. *I was actually there when it finished. IMG_1344.JPG IMG_1345.JPG IMG_1348.JPG
    Final charge and balance:
    • Charge and balance (Started at 82V - Voltage went up quickly after the discharge was done; Ended at 239V): Sunday 11:30am - Monday 6:30am --> 19 hours. IMG_1359.JPG IMG_1381.JPG
    Total time: 81 hours.
    The whole reconditioning process was very easy due to the simplicity of each Prolong device. I think I would've cut back some time if I checked on the charging and discharging more. Since finishing on Monday morning, I only drove about 15 miles to work and back. I believe that my Prius might still re-calibrating after the reconditioning. I have heard that it could take some more driving until it is done. I will update this post with some more thoughts and findings later.
    Jdz67, wvs2003, Chodronish and 13 others like this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Thanks for the thread and information (y)!
    How many miles on your 05? Did you have a code that prompted the reconditioning, or just preventative maintenance?
    I have the Prolong Charger and Intelligent Discharger and will be doing a similar activity over Memorial Day weekend :).
    All I have done so far is a top up balance and have seen better battery life waiting in traffic.
    Keep updating us with data from your experience(y).
    MelSmith, Ajourney101 and WilDavis like this.
  3. biglew8
    170
    114
    Seattle
    Not a problem! So sorry for not posting my total miles! It has around 171,900 miles. I did not have any codes. I did the reconditioning as a preventative maintenance. I'm looking forward to reading your post if you document your experience! Can you please elaborate more on "better battery life waiting in traffic?" Thank you!
    Ajourney101 and Raytheeagle like this.
  4. JC91006
    16,936
    8,647
    Wow the voltage bounce is pretty extreme. 134v to 165v, 84v to 170v, 17v to 82v? Damn I wonder if there's something wrong with the discharger. 10 to 15 percent difference maybe, but your numbers seem way too high.
  5. biglew8
    170
    114
    Seattle
    I wondered that too. I'll let @jeff652 answer that. I hope it's nothing is wrong because I spent a lot of time doing it.
  6. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    No problem on posting results ;).
    Our 2010 Prius II has 154 k miles on it and going strong. In the Bay Area during peak commute time, my perception of our HV battery was that over time I have lost some distance that I could run only on the battery prior to the engine kicking on. I also had noticed that I wasn't getting 7 bars worth of battery charge, and I was at around 150 k miles (the end of battery warranty).
    So after performing just a charge top up cycle, I am seeing a fuller battery (I frequently hit 7 bars now) and longer distance prior to the engine kicking in (this is not miles increased but more time, which corresponds to increased mpg:)).
    I am an ok weekend wrencher, but the one area I have not delved into was the HV Battery. So @jeff652 makes that a little easier and safer;).
    Hope that helps (y).
  7. biglew8
    170
    114
    Seattle
    Very nice! I need to drive my car more and report back findings. It seemed that I used to get into the green area easily. I heard it's rare unless you're going down a steep hill. Even a small hill would get me into the green. I'm going to see if it's still happening.
  8. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    Thank you the write up and pictures. I'm expecting my Deluxe Package to arrive this week. I'm not a huge DIY guy so it puts my mind at ease to know it's not that complicated. Babysitting the system while it's working I can do...I have a grandson ;)
    Like biglew8 our battery is not throwing any codes but it is showing some signs of age. I'm going to do the conditioning as "insurance" before our lengthy trip in July. The plan is to have the 120k service done a little early and then my son will install the wiring harness in June.
    Ajourney101, Raytheeagle and biglew8 like this.
  9. biglew8
    170
    114
    Seattle
    That sounds like a good plan! It's really "set it & forget it." As for the discharges, I would say start maybe checking it around the 4 hour mark to see where it is at. If the car is close to you like in a garage, you should be able to hear the beeping alert telling you that the discharge is done. I couldn't hear mine because my car was in my neighbor's garage.
  10. srellim234
    1,201
    1,694
    Laughlin, Nevada
    Our garage isn't attached but it won't be a problem hanging out there. I have an exercise bike and weight machine out there plus my bicycle can always use some maintenance and cleaning.
    Ajourney101 and biglew8 like this.
  11. biglew8
    170
    114
    Seattle
    Here are some some thoughts and findings from the morning drive to work:
    1. Battery stayed between 5-6 bars. I mainly noticed the drop down to 5 bars when I was stuck in some light traffic.
    2. I've noticed going into the green bar area (7-8 bars) once. This is when I was cruising down a small decline while exiting the freeway. I used to get in the green area easily even without any hills. We shall see if it still happening as I drive some more.
    3. Electric engine is lasting a little longer than just 10mph. It's most likely due to me being gentle with the gas pedal.
    4. I've noticed that the engine would force charge the hybrid battery when it is around 5 blue bars and idling. I could hear and feel the engine running and also see the MFD show the force charge from the engine to hybrid battery. I am not sure if this is happening due to the reconditioning. It used to only force charge when it was at 2 bars.
    I will update again when I have more things to share!
    offib, jeff652 and Raytheeagle like this.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Good write-up! And thanks for the pix. I'll be waiting to hear further reports as you drive it more.
    Your experience is pretty similar to mine on the battery voltage bouncing back up after discharge. I have the manual discharger, so I have to be right there as it nears completion. Therefore, I don't know how high it would bounce, but in the brief time between disconnecting the discharger and connecting the charger it was amazing how quickly the voltage would climb. It will soon be time to give my wife's '07 another conditioning. I try to do it 3-4 times a year.
    Raytheeagle, fotomoto and biglew8 like this.
  13. biglew8
    170
    114
    Seattle
    Thank you! I'm sure @jeff652 will chime in soon regarding the voltage climbing up. I know I've read that it is normal for it to climb back up but not sure if my situation is normal or not since it was a lot.
  14. JC91006
    16,936
    8,647
    Patiently waiting.......
    Chodronish likes this.
  15. srellim234
    1,201
    1,694
    Laughlin, Nevada
    Speaking of patiently waiting, my Prolong system was delivered a few hours ago but my son's not going to be installing the harness until June 10th or 11th.
    FWIW it was ordered May 8th and came well protected in the package. I'm very pleased with the ordering and shipping.
    jerrymildred, biglew8 and Raytheeagle like this.
  16. biglew8
    170
    114
    Seattle
    After work drive thoughts & findings:
    1. The battery is still staying mostly in the 5-6 blue bars area. It went down once to 4 blue bars. That was due to being stuck in traffic waiting for a train to pass.
    2. The gas engine shuts off quicker than before. Prior to reconditioning, the gas engine would shut off about 5-10 seconds after coming to a complete stop. Now, the gas engine shuts off even before a complete stop (Like around 1mph).
    3. Battery bars did not go down driving up a hill. I was around 4 blue bars when I started to go up a hill. More than half way up, I actually gained one bar for a total of 5 blue bars. Prior to reconditioning, I used to lose battery bars going up a hill.
    4. I went down a big hill and the battery did not go into the green area! It stayed at 6 blue bars the whole way down. Prior to reconditioning, even the smallest hills would cause the battery to get into the green area (7-8 bars) quickly.
    I would have to say that I'm actually starting to notice positive results from reconditioning the hybrid battery!
    offib, jeff652, srellim234 and 3 others like this.
  17. jerrymildred
    11,517
    14,167
    Tampa, FL
    Awesome!! It sounds like you've regained considerable battery capacity. That would make a great testimonial on Jeff's site.
  18. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Yes, good news on the capacity! Any mpg change will be interesting to see, as you drive it more.
    blrose1228, offib, jeff652 and 3 others like this.
  19. biglew8
    170
    114
    Seattle
    I'll have to see what the average mpg will be over the next couple of fill ups. It's mainly been city driving since the reconditioning. Once I do some highway driving, the average mpg should go up. I think I've only driven about 30 something miles since filling up on Monday. The average mpg has been fluctuating quickly since there isn't many miles driven yet on this tank. Interesing thing to note is that my last tank averaged 44mpg. That was the best I've seen since buying my Prius back in February. 44mpg is within the Fuelly average for 2005 Prius. I'm wondering if I'll continue to see an average of 44mpg or maybe even an increase. Stay tuned!
    blrose1228, WilDavis, jeff652 and 2 others like this.
  20. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    Nope, nothing wrong with the discharger. Voltage rebound is expected, normal, and will vary depending on the battery and DoD. Nothing to be alarmed about.
    We need to make a video about this because we do get calls on it. I need to clone myself so that I can have enough time to get this (and the other 75 videos I need to make) done hahah
    #20 jeff652, May 18, 2017
    WilDavis, offib, Raytheeagle and 4 others like this.
