Reconditioning Experience with Hybrid Automotive's Prolong System
Discussion in 'Gen 2 Prius Main Forum' started by biglew8, May 16, 2017.
  1. timmyjane
    timmyjane Junior Member
    87
    SC
    Anyone know if there is a rental program for the charger?
    kenoarto likes this.
  2. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    I think you'll either have to find a mechanic who has invested in one to do it for you as part of his business or find an individual with one who will let you borrow or rent it.
  3. biglew8
    biglew8 Active Member
    170
    114
    Seattle
    Even if you find someone to borrow the charger, you will still need the wire harness installed.
    Raytheeagle likes this.
  4. isano.chan
    isano.chan Junior Member
    Indonesia
    Where to but prolong system device and how much does it cost?
    SM-N9208 ?
  5. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Start a conversation with @jeff652 and He'll be able to assist.
  6. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I saw similar behaviour when I first used my Intelligent Discharger, but I checked with @jeff652 who assured me what I was seeing was normal, and was nothing to worry about!
    biglew8 likes this.
  7. fotomoto
    fotomoto Senior Member
    5,638
    3,813
    So. Texas
    I have the same thing happen (voltage bounces back up) when I change out bulbs on my "unintelligent" discharger. :)
    Raytheeagle and WilDavis like this.
  8. JC91006
    16,768
    8,565
    I use an unintelligent discharger as well but I've never checked the voltage after I discharge. I just hook up the charger and charge it back up. So this extreme bounce is new to me. I'll check on the pack I'm reconditioning now to see if I see the voltage bounce.
    I was thinking with a 25w bulb, the current is so low that the voltage wouldn't bounce so much. But I'll check. So much great info here.
    WilDavis, biglew8 and jeff652 like this.
  9. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    WilDavis, Raytheeagle and biglew8 like this.
  10. biglew8
    170
    114
    Seattle
    Your post on your reconditioning experience inspired me to do the same. Thank you for that!
    Raytheeagle, WilDavis and jeff652 like this.
  11. biglew8
    170
    114
    Seattle
    I drove some more today and got some highway driving in. Average mpg is around 41.5. My gas tank is still full according to the gas guage. Plenty of driving left for this tank of gas! I hope I can surpass my best of 44 mpg. The 44 mpg average was achieved without hypermiling and before hybrid battery reconditioning.
  12. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Nah, both of those situations are totally normal. You need to read up on the different stages of hybrid operation. http://techno-fandom.org/~hobbit/cars/five-stages.txt
    Regarding the pack voltage bouncing back after the discharge load is removed, again totally normal. From my experience with Nickel chemistry packs in general (power tools etc), a healthy cell (both NiCd and NiMH) will normally bounce back to somewhere roughly about about 1 volt per cell (0.9 to 1.1 typ) within a few minutes after the load is removed. This corresponds to about 160 to 170 volts for a complete Prius pack (28x6 = 168 equiv cells).
    In fact, not bouncing back properly is a good sign of a faulty cell. Cells that "underbounce" (say for example stay below 0.5 volts) tend to have higher than normal leakage, and cells that "overbounce" (say that bounce all the way back to 1.2+ volts) tend to be high impedance.
    #32 uart, May 21, 2017
    Robert Holt and SFO like this.
  13. JC91006
    16,768
    8,565
    All the packs I've reconditioned, I've rarely ever gone below 134v on discharge. The packs were never degraded that badly where such extreme discharges were needed. 134v is basically empty already. This also reduces the chance of cell damage due to reverse charge
    SFO likes this.
  14. srellim234
    1,201
    1,694
    Laughlin, Nevada
    Being the novice that I am at all of this, should I only do the first discharge cycle instead of all three since my battery hasn't thrown any codes yet?
  15. JC91006
    16,768
    8,565
    My opinion is to do 3 cycles all down to 134v. No need to go below that as the pack is a good functioning pack.
  16. WilDavis
    2,493
    2,155
    49
    Well, to my way of thinking, that sounds like not bothering with the insurance which covers no-deductable-loss windshield damage since the car has never suffered windscreen damage before, and the car is new enough not to have a badly scarred windscreen. C'mon it's a type of insurance and just as essential as doing any other preventative maintenance on the car! The latter part of the lower voltage discharges and the low current at those points are necessary for the discharges to be most effective! (well, that's how I understand it!) - hope this helps - Wil
  17. srellim234
    1,201
    1,694
    Laughlin, Nevada
    Thank you. Fortunately I'll have enough time between conditioning and our long trip to take a weekend run to visit other family. That will give me a chance to check out if things are looking good regarding performance (is it still quick up and down on the screen, has mpg changed over a familiar drive, etc.) . If things still look funky be ready for more questions! :D
  18. JC91006
    16,768
    8,565
    The battery is technically empty at 134v. The only reason to go lower is if discharging to 134v still does not improve the battery capacity. Going below .8v per cell gets into the danger zone. I personally have not had a reason to go that low, all the reconditioning down to 134v has yielded positive results without the added danger of going below that threshold.
    Using a grid charger does wonders when discharging to 134v, charge and balancing afterwards. Results may be different with hobby chargers doing individual modules, but when using a grid charger at the pack level, 134v is a sufficient level of discharge before you charge and balance.
    If you have a battery that has 300k miles and is really weak, you may want to go lower. I don't feel a good battery needs that danger, especially if you're just doing a reconditioning charge and balance
    WilDavis likes this.
  19. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Very nice write up and photos. I just wanted to mention that while waiting for traffic, trains , lights you can force charge it to the desired level.
  20. JC91006
    16,768
    8,565
    Remember the prius battery is suppose to be maintenance free, if you're spending time needing to constantly maintain it, then you're probably doing something it wasn't designed to have.
    Force charging? That won't save you any gas and that's the whole purpose of the prius
