Reconditioning Experience with Hybrid Automotive's Prolong System
Discussion in 'Gen 2 Prius Main Forum' started by biglew8, May 16, 2017.
  1. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    …and here is:
    Dschrg to 84 V - 6:45 hours ("dead-cat-bounce" had taken the V back up to 190V when I checked!)
    …onward & upward!
    (…bloody garage 20degrees (F)!! …buggeration! …talk about brass-monkeys! o_O :eek:;))
    #521 WilDavis, Dec 28, 2017
    Raytheeagle and Prodigyplace like this.
  2. WilDavis
    2,493
    2,155
    49
    …and
    Chrg3: 33½ hours 249V 356mA (…temp in garage = 12deg! :eek::eek::eek:) (…outside it's -2degF :eek::eek::eek::eek:)
    SFO and Raytheeagle like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    And I thought it was cold here at 37 F this morning :rolleyes:.
    I guess it could be worse:whistle:.
    WilDavis likes this.
  4. Prodigyplace
    12,564
    11,779
    Central Virginia
    My Prius said 20 F.
    Raytheeagle likes this.
  5. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    I haven't been in weather that cold since I spent the winter in Chicago ten years ago.
    Out here we're in another dry, warm spell. The low was 53* last night and the high will be in the mid 80s today. The drought is back too. Since the beginning of October we've had a whopping 0.1 inch of rain.
    You people be careful. When it comes to weather, your situation is a lot more dangerous than mine.
    WilDavis and Raytheeagle like this.
  6. WilDavis
    2,493
    2,155
    49
    …sounds positively balmy!! :) …just take care with those matches! :eek:
  7. WilDavis
    2,493
    2,155
    49
    …and for those pedants:
    Dschrg to 17V ~ 7 hours (I started checking around 6:45, and the meter was at 60V, and dropped at 10V every 6 mins or so, and I was able to hit the 17V on the nail)
    …and so to final LongSoaker! :)
    …and I thought as I looked around at all the moth-balls on the floor of the garage (see threads passim) how almost appropriate (temp in garage was at 22 deg F :eek: :rolleyes:)
    Prodigyplace and Raytheeagle like this.
  8. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Looks good:).
    Enjoy the next 40 hours ;).
    Hopefully it has warmed up some (y).
    Prodigyplace likes this.
  9. Prodigyplace
    12,564
    11,779
    Central Virginia
    After all that charging, the battery will be used to being warm. Do not forget to put a fur coat on the car before venturing outside. ;):oops:o_O:cautious:
    Raytheeagle and WilDavis like this.
  10. WilDavis
    2,493
    2,155
    49
    Thanks! 9F here in Nausea, and a toasty 22F in garage! ;)
  11. WilDavis
    2,493
    2,155
    49
    :D:D:D
    …interesting you mention the warm battery, I listened hard to the fan and it was most definitely changing speed as the charging started up - sounded just like it was shifting up through the gears! Almost drowned out by the fans on the IntelDischarger, but the fan on the charger is larger and very quiet by comparism!
  12. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    We just hit 59 out here and very few clouds in the sky:p.
    Throw another log on the fire for me(y).
  13. WilDavis
    2,493
    2,155
    49
    Beautiful blue sky here, but the snow is just perfect for X-Country skiing, and the snow squeaks when you walk in it! …and little (<20%) humidity at the moment!
  14. Prodigyplace
    12,564
    11,779
    Central Virginia
    My phone says it is a balmy 38 here, headed toward 21 tonight.
  15. Prodigyplace
    12,564
    11,779
    Central Virginia
    If I wished, I could go skiing here in the summer, but long sleeves & long legged pants are needed. I understand the "rug burn" of the "snow" is a real pain.
    Liberty Mountain Snowflex Centre
    Since this is a tech site
  16. WilDavis
    2,493
    2,155
    49
    Sumer is i-cumin in—
    Lhude sing, cuccu! ;)
  17. WilDavis
    2,493
    2,155
    49
    Nice picture! I bet the only squeaks heard there are from the skiers as they get "rug burn" ;)
  18. Prodigyplace
    12,564
    11,779
    Central Virginia
    Think extra long Velcro.
  19. WilDavis
    2,493
    2,155
    49
    Yikes!!! :eek::eek::eek:;)
  20. srellim234
    1,201
    1,694
    Laughlin, Nevada
    Just got back from my son's. The car was definitely a little stronger up Cajon Pass and the battery stayed where it's supposed to (top blue, bottom green bar) almost the entire trip. It was definitely a lot smoother and the ICE wasn't working nearly as much as it was a few weeks ago. I can't point too much of the improved mileage at the batteries, though, because traffic was a little unusual and at 55-57 mph instead of the normal 65-68 mph on highway 395 much of the time. But, for a car that normally gets 44 mpg on this round trip it did get 48 this time.
