Reconditioning Experience with Hybrid Automotive's Prolong System
Discussion in 'Gen 2 Prius Main Forum' started by biglew8, May 16, 2017.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    I believe with the automatic discharger, you have to select the target voltage. Did you remember to set it to 84V as you began the 2nd discharge cycle?
    Prolong® Battery Discharger User Guide – Hybrid Automotive
    srellim234 likes this.
  2. calin.ceascai
    calin.ceascai Junior Member
    RO
    Of course but the first case set to discharge 134V and last time that I checked the voltage was 143V. After 1 hour the discharger was idle, buzzer on voltage 151V. So may be I was late with checking the status. Is this possible?
    Huawei P10 Leica
  3. Prodigyplace
    12,564
    11,779
    Central Virginia
    That number appears to be within the bounce-back range mentioned in post 640. I remember discussions about this when the intelligent discharger first started shipping. @jeff652 assured people this was to be expected.
    Raytheeagle and jerrymildred like this.
  4. jerrymildred
    11,517
    14,152
    Tampa, FL
    Probably. It bounces back quite a bit when you stop discharging. I have the manual discharger (light bulbs) and it's pretty amazing to watch the volt meter climb when I unscrew a bulb to change them.
  5. calin.ceascai
    RO
    This bouncing back is not hurting the hv battery?
    Huawei P10 Leica
  6. jerrymildred
    11,517
    14,152
    Tampa, FL
    Nope. It's normal battery behavior. All rechargeables do that as far as I know.
    Raytheeagle likes this.
  7. calin.ceascai
    RO
    Thanks.
    Huawei P10 Leica
  8. jerrymildred
    11,517
    14,152
    Tampa, FL
    Happy to help. Once my wife's battery gets old enough to need grid charging, I'll definitely be wanting one of those automatic dischargers. I have the old original square, black Prolong with the lightbulb discharger. Lots of babysitting there.
    srellim234 and Raytheeagle like this.
  9. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    I'm on my third discharge now, and there might be some rain during the final charging. Is it "safe" to pause during this charging in order to roll my other 3 windows up? I assume stopping the charge midway and resuming once the weather passes is even less advisable.
  10. calin.ceascai
    RO
    I just finished the third discharge that to 17 V. Now one more step. Final charge and balancing. Screenshot_20180320-220222.jpg
    Huawei P10 Leica
  11. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    You can roll the windows up;).
    The bulb discharge guys have to take momentary pauses to change bulbs:whistle:.
    Good luck and keep us posted (y).
  12. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    I’m impressed you caught the exact voltage:).
    It cycles pretty quick at the very low voltages;).
    Keep us posted (y).
    calin.ceascai likes this.
  13. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    Surprised you were able to catch it right at 17. Watched mine from 18-17 and as soon as it hit 17 it immediately shot up to 30+
    welp, I've already started the last charge, so I assume it's not a good idea to do so without waiting for an hour or more for the battery to cool
  14. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    You can use accessory mode as that won’t engage the hybrid battery
    And rolling the windows up only takes a few seconds:).
    Or open the doors and put blankets or towels over the windows, then close the doors and it will prevent severe water intrusion (y).
    #654 Raytheeagle, Mar 20, 2018
    jerrymildred and k1ngn0thing like this.
  15. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    Reconditioning the pack made the bad module/s worse (was only .02 off prior).
    I expect I'll find corrosion on the connection. Wonder if cleaning this first would have allowed the prolong process to work. If anyone knows of a shop in New England that will replace the bad module/s and clean the bus bars for a reasonable price, I'm looking for suggestions.
    mjoo, VFerdman and Raytheeagle like this.
  16. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Odd that the delta is not reflecting that difference in voltage of block 7.
    The prolong works best if the pack is just tired and has not thrown codes yet. Fully discharging and chArging will sometimes reveal a weak module,
    But at least you have rejuvenated the rest of the modules,
    The whack a mole pack rebuild is dicey. If you find a rebuilder locally and hopefully not in Craig’s list post them here first for reviews. Some are really bad and outright crooked.
    I wish PC would have a battery rebuilder forum. Just reviews of pack rebuilders and posters could post there experience with them. Now there all over the place.
    If you find a rebuilder try searching his name in the Search Forums button on top of this page.
    jerrymildred and Raytheeagle like this.
  17. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Check out the hybrid automotive website as there is an installer map;).
    I’d try calling them and seeing what they do and if they don’t, they might know someone who does :).
    Block 7 is your suspect though(y).
    jerrymildred and edthefox5 like this.
  18. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    waiting to hear back from Priuskings and HybridAutomotive. no option but to play the mole game (and my pack is supposed to be new, 8k miles ago).
  19. dolj
    dolj Senior Member
    8,446
    4,291
    Wellington, New Zealand
    It is probably more of a case that Block 7 was not capable of being recovered whereas the other blocks have been balanced.
    Block 7 indicates problems with at least 2 cells within the block, One in each module? Or both in the same one, if you're lucky.
  20. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    replacing both just to be safe. will diagnose them later to see which, if either, is worth keeping
