Reconditioning Experience with Hybrid Automotive's Prolong System
Discussion in 'Gen 2 Prius Main Forum' started by biglew8, May 16, 2017.
  1. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    this makes sense, thanks
  2. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    is there any way to flatten out a module? one of the 2 I ordered from Hybrid Automotive was slightly bent and so I couldn't install both (the other had a less severe bend). luckily only one of the 2 in the block needed replacing.
  3. Prodigyplace
    12,563
    11,778
    Central Virginia
    I suspect @jeff652 would replace it. Perhaps inadequate packaging before shipping?
  4. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    the box was a little beat up and not much bigger than the diagonal on these so I suspect it got dropped on the corner. waiting to hear back from customer support
    #684 k1ngn0thing, Mar 30, 2018
  5. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    Snap a few pics of it and call us on Monday, we'll send a replacement to you.
  6. Hybrid Battery Exchange
    67
    86
    Portland, OR
    Bent modules are usually the ones that sit on the outside of the pack, #1 and #28. Unless it's extremely bent you should be able to use it.
    jeff652 likes this.
  7. Prodigyplace
    12,563
    11,778
    Central Virginia
    That may be true but the business owner already offered a replacement in the post above yours.
  8. fotomoto
    fotomoto Senior Member
    5,638
    3,813
    So. Texas
    I saw similar when I completely disassembled my pack to shuffle all the modules during a repair. Once I tightened the big bolts, it sandwiched them back to parallel and all the small mounting screws lined up. FWIW
  9. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    believe me I tried it on the end and there was no way I was getting that thing to fit, and doubt it would have been an easy job even with another set of hands.
  10. JC91006
    16,768
    8,565
    You people should be removing the exterior case from the modules.
    1. Remove the bus bars
    2. Remove the 8mm bolts from under the case
    3. Remove the 2 10mm nuts on the case corners
    4. The bottom of the case should come off.
    Now you're free to work on the modules without having to disfigure the modules, the case or your hands
  11. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    not sure that would have helped as there's no real a way to push the modules together while trying to get the end piece on. even without the bent module I had to put the end in, then force the last module in the remaining space.
  12. JC91006
    16,768
    8,565
    There's not suppose to be any pushing, it suppose to be effortless. The modules are held together by their clamps. 4 12mm bolts on top (you only need to loosen 2 on 1 side), 4 12mm bolts on the bottom (you also need to loosen 2 of these on 1 side). Once those bolts are tightened, they should fit perfectly into the base of the case.
    You are NOT suppose to unbolt the clamping bolts until you remove the 28 modules from the base of the case. If you're following youtube videos, then there might be a problem because 99% of them are doing it wrong
    jerrymildred and Raytheeagle like this.
  13. Hybrid Battery Exchange
    67
    86
    Portland, OR
    I'm pretty sure his issue was caused by the fact that he was working with a hot pack, fresh out of the car or off the charger. The modules build internal pressure while in use and swell, the caged keeps them tightly together and this is the cause for the bent outside modules. It takes 6 to 12 hours for them to cool off before they can be disassembled/assembled without much hassle.
    Prodigyplace, Raytheeagle and JC91006 like this.
  14. JC91006
    16,768
    8,565
    Oh yes, never work on a hot pack, need to let it rest overnight
    Prodigyplace and Raytheeagle like this.
  15. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    neither was the case. car had been sitting cold for 3+ days
  16. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Here we go.
    I've got a 2005 Prius with 212,000 miles. We bought it 6,000 ago with a dead battery. I replaced block 8 and got it running....for 5 months, then the next mole appeared, so I whacked block 5.
    I've now got it on the first charge of a recondition.
    Currently about 60F outside.
    Starting voltage 236v.
    I haven't found a definitive instruction as to when to stop the charge. Is there a certain voltage?
    Raytheeagle likes this.
  17. JC91006
    16,768
    8,565
    Charge for about 24 hours and then start the discharge. Since you've done it 5 months ago, you're probably only needing 1 or 2 discharges and you'll be good to go
  18. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    240V is a great target, and if you check previous threads, you'll see that some of my "long soaks" have ended up at 240V (after about 40 hours) - so 240V has become my target, and I'll be doing a ½ yearly full-recondition at the end of this month, so watch this space! ;)
  19. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Hmmmmm I've gone from 236v start voltage, and I just checked, after 4 hr 40 mins I'm at 239v. Does that sound reasonable or is that a bit quick, hinting at a poor battery?
  20. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    Mine is plugged in as we speak. Time for the every 1/2 year full recondiiton. After the long 40 hour soaks in December things have been much more stable and the charge-only cycle in March held up better. I think I'm going to back off a little though because the temperature is already pretty warm here. This time I'm going to try to get away with only two discharge sessions (skipping the lowest voltage one) and I won't go anywhere near 40 hours on a charge. I'll go long in December again.
    If it works, great. If it doesn't I can always give it a boost a little ahead of schedule.
