Reconditioning Experience with Hybrid Automotive's Prolong System
Discussion in 'Gen 2 Prius Main Forum' started by biglew8, May 16, 2017.
  1. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    The benefit varies from battery to battery based on that batteries condition, so it's hard to say empirically that exactly three cycles is the number everyone should use. However when selling a product customers generally want to know how many times to use the product, so three was settled on as the balance between time required and benefit. More cycles do seem to help - but it's a diminishing return, you are consuming cycle counts on those cells, and most people don't want to put that much time into it. We have seen benefits cycling some packs up to five or six times, especially weaker packs tend to respond well to additional cycles. Having said all this, If you want to cycle your battery a couple more times, go for it.
    offib, WilDavis, mjoo and 1 other person like this.
  2. DanIL
    DanIL Junior Member
    42
    64
    Northern Illinois
    I did not get a chance to recondition again over the 4th weekend. But, I appreciate getting "clearance from the tower." I'll post data next time I do.
    Jeff (and George), thanks, from a recent HA customer, for all the valuable info and contributing on this site.
    jeff652 and Raytheeagle like this.
  3. Phildo
    Phildo Active Member
    138
    109
    Perth, Western Australia
    i-Tech
    What the best combination of cycling modules with individual chargers and then using the Prolong equipment?
    ie
    - Using chargers such as Turnigy Reaktors, I discharge & recharge each module three times, with the third discharge giving me the mAh capacity of each module. This all goes into a spreadsheet.
    - Modules that are showing a low capacity get replaced with modules with a suitable matching age and capacity.
    - So far I've then been using the Prolong charger and discharger to cycle the whole pack three times.
    Considering that the modules have already been cycled three times individually, how should I be using the Prolong equipment?
    - Just run the charger for a handful of hours (12?) to balance the modules?
    - Run the three charge & discharge cycles (163V, 102V and 20V discharge for a Camry battery; 134V, 84V and 17V for a Prius battery)?
    - Charge and then just run one or two of the discharges? If so, which one?
  4. Kuang
    Kuang Member
    37
    38
    US
    40AF4C5A-D613-48D7-AD05-2E211E0DFF7A.jpeg Hi Jeff652,
    I used your recharger few times already, however this time it shows a low voltage as 212v after 12 hours (picture attached below). My car is Prius 2010. Is it a sign of problem? Thanks
    Hi
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    I do not see any current reading should show like .335 amps. Roughly 1/3rd of an amp.
    Raytheeagle likes this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Mind describing conditions that predate the 212 volt reading?
    Is there any backstory or pertinent information about the Prius?
    Has it been showing 0.002 on the current the whole time?
    Skibob and Prodigyplace like this.
  7. Phildo
    138
    109
    i-Tech
    Just a wild guess - remove the orange safety switch and put it back in. Make sure that you push the loop downward - it doesn't work if the loop isn't pushed back into place (you'll feel it click in).
  8. Kuang
    Kuang Member
    37
    38
    US
    Thank for all your responses. The recharger is broken. I contacted tech support who gave me a RMA to send it back for repairing.
    Robert Holt and Raytheeagle like this.
  9. Liam howard
    Liam howard Junior Member
    56
    24
    United States
    Four Touring
    Hello everyone! I sense my hybrid battery is starting to get tired. It just reached its 10th birthday and I want to recondition it with the prolong system. However, it is out of my price range right now and was wondering if these chargers are available to rent or something similar. Any input? Thanks in advance!
  10. Prodigyplace
    12,547
    11,772
    Central Virginia
    I know some people have pooled together to share the price of a system but each have their own harnesses. @Raytheeagle is one.
    SFO, srellim234 and Raytheeagle like this.
  11. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    I was one;).
    But it is a great system to share as you only use it periodically throughout the year :).
    It’s also nice to meet other owners and swap stories as part of ownership (y).
    SFO, Skibob and VFerdman like this.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,150
    Tampa, FL
    In order for anyone to know if they can help, they'll need a little more location precision from you than just "United States." If someone is close, they will probably help, but you'll want to at least get the harness from Prolong.
    Skibob, srellim234, WilDavis and 2 others like this.
  13. Liam howard
    56
    24
    United States
    Four Touring
    My name is Andrew and I live in the Philadelphia PA. Would definitely be willing to pool funds or do whatever else it takes to be able to gain access. Anybody from Philadelphia or nearby?
  14. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Not sure what members have the equipment yet, but our equipment sharing started out here by me jumping in first, then finding other members in my local area;).
    Depending on what you consider local, you might be able to get some members out to Harrisburg :).
    @trentofdestiny might be down(y).
    SFO, jerrymildred and Prodigyplace like this.
  15. ericbecky
    ericbecky Hybrid Battery Hero
    4,431
    3,304
    Madison, Wisconsin
    I have offered to rent them but got no takers.
    You pay full price for the unit.
    It is shipped to you.
    You use it in a reasonable.
    You send it back to me.
    You get your money back less rental and shipping fee.
    If you don't send it back in a reasonable time, then you bought it.
    Or save yourself the hassle and just build one for $150 or less using an off the shelf power supply.
    Or repurpose a power supply from something like an eletropherisis machine. Still around $150.
    Liam howard, SFO and Fred_H like this.
  16. Borninblue
    Borninblue Active Member
    233
    158
    Cleveland, Ohio
    Been waiting for someone in northeast Ohio to come through with one myself to rent!!
  17. ericbecky
    4,431
    3,304
    Madison, Wisconsin
    I can rent one anytime.
    How does $300 per use sound?
    Prodigyplace likes this.
  18. Borninblue
    233
    158
    Cleveland, Ohio
    Is there a harness to purchase as well? 200.00 and I would feel comfortable with the hassle of shipping involved.
  19. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Security deposit? (...sorry, is there an echo in here?)
    Raytheeagle and Prodigyplace like this.
  20. ericbecky
    4,431
    3,304
    Madison, Wisconsin
    Yes. You need to purchase and Install a harness.
    Deposit is full cost of item, which reverts to a purchase after 21 days.
    Seriously, you'd be better off buying one yourself and just sharing it locally.
