Reconditioning Experience with Hybrid Automotive's Prolong System
Discussion in 'Gen 2 Prius Main Forum' started by biglew8, May 16, 2017.
  1. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    What was the issue? It was impossible to determine it wasn't working properly from your picture.
  2. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    I just ran Dr. Prius app on my 07 with 165k miles on it and it came back 79%.
    Based on that I’m guessing this is good candidate for reconditioning ?
    I don’t have outdoor electric outlet so I have to run cord out from inside, given it’s winter maybe run one charge and balance then do the five day charge/discharge in the spring when I can have windows open?
  3. universeisgr8
    universeisgr8 Junior Member
    Virginia
    Can the prolong battery charger and discharger be used on a battery that has been taken out of the car? I dont have a way to run the cable to the parking lot.
  4. Ds001001
    Ds001001 Member
    81
    34
    Tahoe North Lake
    Yes , some people also disassemble the pack and change bus bars and clean the terminals. If you get it inside you may as well take the extra time to do that
    video of full dissemble
    offib and srellim234 like this.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    It can used out of the car but when out of the car the battery’s fan system no longer works so you must cool the battery’s really well with fans and monitor the pack temp.
    And never release the mechanical tension on the battery while charging.
    When unclamped the battery’s will swell and the pack will be ruined.
  6. Chba
    Chba Junior Member
    93
    New york
    Hello, I have started the reconditioning procedure for my high voltage battery of my "prius" gen3 200k miles "hybrid car, as a preventive measure. My dashboard does not throw an "error" light. I also do not have any batterycode with the Techstream software. But, the test with "Hybrid Assistant" proves that I have 4 weak blocks (5,6,7,8) which pull the pack down.
    I use the "PROLONG DELUXE CHARGER" for the first time . I have a few questions regarding the procedure.
    First, I started the process on Friday evening, I did 3 charge-discharge cycles ", but I did not leave a break between cycles. I went directly to the" charge-discharge-charge ". Is there any danger to my battery? The maximum ambient temperature is 33 degrees Celsius.
    Second question: I am currently finishing the final charge and final balancing, I plan to charge it at least 24h. My question is, 30 minutes after the end of the final charge, should I discharge to the rated voltage before starting the car?
    Here is an overview of the procedure in excel file.
  7. Phildo
    Phildo Active Member
    138
    109
    Perth, Western Australia
    i-Tech
    Another good video for disassembling the hybrid battery:
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    No, this is pretty much standard procedure.
    As long as you wait at LEAST 30 minutes before driving, it should be OK, but waiting longer won't hurt anything. Neither will doing a bit of a discharge with the Prolong. You can also discharge by starting the car and immediately shifting to neutral and then turning on the air conditioner and headlights. Then you can watch the HV battery monitor on your dash. Neutral prevents the car from charging the battery since it doesn't yet realize how full the battery is after you finish balancing it.
    srellim234 and Prodigyplace like this.
  9. Chba
    Chba Junior Member
    93
    New york
  10. Chba
    Chba Junior Member
    93
    New york
    Thank
  11. srellim234
    1,201
    1,694
    Laughlin, Nevada
    In addition to what jerrymildred posted, pay attention to the overall temperature. You're fine at the current 33 degrees Celsius but don't use the Prolong system when it exceeds about 37.5 degrees Celsius. At that temperature it can't efficiently "bleed off" the excess heat generated and you could further weaken a cell..
    jerrymildred likes this.
  12. Chba
    Chba Junior Member
    93
    New york
    Ok, thank you. But During my final charge and balancing, the battery voltage after 12 hours of charging is equal to 239 volts and after 24 hours it is 237 volts. Probably, the voltage reached its peak before dropping down to 239 volts.Is this normal?
  13. Chba
    Chba Junior Member
    93
    New york
  14. jerrymildred
    11,517
    14,152
    Tampa, FL
    Sounds pretty normal. Sometimes it can get a little over 140, but it'll fluctuate a few degrees as it balances.
    srellim234 likes this.
  15. dolj
    dolj Senior Member
    8,446
    4,290
    Wellington, New Zealand
    Did you mean 240? :unsure:
    jerrymildred and Prodigyplace like this.
  16. jerrymildred
    11,517
    14,152
    Tampa, FL
    Yes, I did and now the edit button is gone. :oops: Thanks for the fumble recovery. Oops! That's American football. :D
    Prodigyplace likes this.
  17. Prodigyplace
    12,560
    11,778
    Central Virginia
    I thought 140 degrees was involved in you frying the pack being too impatient.:rolleyes:
  18. jerrymildred
    11,517
    14,152
    Tampa, FL
    LOL! The ambient temperature was getting close to that. That was one stinkin' hot day.
  19. Chba
    Chba Junior Member
    93
    New york
    But today is first day of travel of my prius gen3 2010 200k miles after the "reconditioning HV battery with prolong deluxe"
    I did two tests:
    - "hybrid assistant hv check battery"
    -Test of the life of the battery with the Drprius software. The hv battery behaves in a weird way, it looks like they've gone crazy. It went up to 80% "SOC" before going down to "20%". But the voltage level was high, even with a SOC at 20%.
    I also felt more torque under acceleration than before.
    What worries me is the result provided by Drprius, it announces a percentage of only 45% of estimated capacity. Here are the results in pictures.
    Screenshot_20210224-185750_Dr%20Prius.jpeg Screenshot_20210224-204109.jpeg Screenshot_20210224-203926.jpeg Screenshot_20210224-190626_Dr%20Prius.jpeg Screenshot_20210224-190820_Dr%20Prius.jpeg
  20. Prodigyplace
    12,560
    11,778
    Central Virginia
    @TMR-JWAP is good at interpreting the days.
