Reconditioning the HV battery using iMax B6
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Berch1943, Mar 23, 2020.
  1. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Can you measure the temperature of the batteries in a free state and later at the moment of maximum charge?
  2. kicker22004
    kicker22004 Junior Member
    50
    Oroville
    When I was first charging them they hit 130f and I got concerned so put a fan on them.
  3. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    IMAX B6 allows you to connect a temperature sensor and turn off the charge when the programmed limit is reached.
    But you can also install a fan to blow air on the battery during the charging process.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    The block furthest away from the battery ecu is block 1. It's on the passenger side.
    When "testing" a battery, you determine capacity by measuring how much power is used while discharging.
    During the charge phase, you can't tell how much power is "filling" the battery vs how much is turned into heat. When you are discharging, all the power has to come from inside that battery.
    There are many threads in the forums about DIY pack repair. Good luck.
    dolj and Brian1954 like this.
