Red Airbag Warning Light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by johnjohnchu, Sep 27, 2016.
Tags:
  1. PapaWill
    PapaWill Member
    137
    25
    Maui, Hawaii
    I overlooked the cause of the issue in order to follow all the service recommendations for code B1801... but what I finally looked at today was a bent prong on the clock spring side of the connector coming from the SRS ECU. So I straightened the pin and pugged it in and FINALLY no more airbag cod/dash light. Thank YOU everyone for your support!
  2. ChapmanF
    19,055
    Well, that would be reported as a B1801 fair and square ....
    Was there any indication of how the prong got bent in the first place?
  3. Prius RT
    Prius RT Member
    131
    Papawill - I am in similar boat. Did you solve the b1801 issue?
  4. Brian1954
    Brian1954 Senior Member
    2,694
    1,077
    South Central PA, USA
    Prius RT likes this.
  5. PapaWill
    PapaWill Member
    137
    25
    Maui, Hawaii
    YES! replace the clock spring!
