Red Alert , VSC light Back on
Discussion in 'Gen 2 Prius Technical Discussion' started by Amir_Selim, Dec 17, 2022.
  1. Amir_Selim
    Amir_Selim New Member
    Florida,US
    Unfortunately the scanner I bought look like not for hybrids can not find any code.
    I bought the car used about 2 years and I didn’t replaced the pump. I did try the video you’ve sent and I put the car in N position and I think before 60 seconds the red triangle , and VSC came on the dashboard
  2. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    As far as the inverter water pump goes, while it would nice to be able to confirm that you have a code for that (P0A93), the physical diagnosis confirms you need to replace the failed pump and be done with it.
    However, you have other more pressing issues and so you do need a way to read all your codes to see what those issues are.
    Amir_Selim likes this.
  3. Amir_Selim
    Florida,US
    Thank you for your help. I will replace it and I hope that will fix the issue.
  4. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Any updates, or closure for this thread?
