red bullet for the 5th gen prius
Discussion in 'Gen 5 Prius Accessories and Modifications' started by wrtboy168, Feb 22, 2024.
  1. wrtboy168
    wrtboy168 Member
    70
    29
    Northern California, USA
    2024 Prius
    looks like there is a red bullet for the 5th gen prius. i would think the toyota prius product team would have improved the camshaft timing oil control valve assembly after several generations. or red bullet engineers are really on to something. could it be placebo?
    any thoughts?
  2. PhoS
    PhoS Active Member
    258
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Waste of money, and it's been proven by dyno testing. The computer commands the oil control solenoid. The aftermarket ones aren't any better at doing the job than the stock ones
  3. Hammersmith
    Hammersmith Senior Member
    2,477
    2,536
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Not to mention that the M20A doesn't use an oil solenoid for the intake cam timing. The variable intake cam is governed by an electric motor. The exhaust cam is still governed by an oil solenoid. I'm in the "it's snake oil" camp.
    Brian1954, TGrracie and KMO like this.
  4. AzusaPrius
    AzusaPrius Senior Member
    2,255
    942
    Where is this dyno test you speak of?
    No links to back up your statement?
    Have you tried one of these yourself?
    Made my Prius a little quicker.
    Use promo code "azusa" to save $$$
    Matth Torrijos and RightOnTime like this.
  5. wrtboy168
    wrtboy168 Member
    70
    29
    2024 Prius
    with the 2zr, it's fairly easy to get to the camshaft timing oil control valve assembly (11101J), but with the m20a, the camshaft timing valve assembly (135A0B) is behind the camshaft timing oil control solenoid assembly (15370).
    i don't have personal experience in this area hence trying to learn more about it. i'm thinking there must be a market for it since there's a similar product from quantum. maybe it's for power users and may not do much for eco mode. would love to know more.
    #5 wrtboy168, Feb 24, 2024
  6. AzusaPrius
    2,255
    942
    Yes for best results it is best to use the car in normal or power modes.
    Matth Torrijos likes this.
  7. Hammersmith
    2,477
    2,536
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Made your gen3 a little quicker or made your gen5 a little quicker? The gen5 M20A uses a completely different solenoid setup than the 2ZR.
    Dyjital likes this.
  8. AzusaPrius
    2,255
    942
    Yes my old 2010 but you either can speculate or know by actually using one.
  9. RightOnTime
    RightOnTime Senior Member
    791
    1,660
    183
    Kidnapped in OC, CA
    So far our shop (Hybridpit) has sold 3 so far of the Quantum version. It’s a tough sell because some people thinks it’s not worth it …cough cough
    If anyone is interested we have a loaner program in which you can try the solenoid for 1 week. If you don’t like it send it back and get your money back.
    Quantum Solenoid for Toyota Prius 2023-2025
    Matth Torrijos and wrtboy168 like this.
  10. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    If you are willing to step up to the plate we have a loaner program Takes about 5 minutes to install.
    iPhone ?
  11. PhoS
    PhoS Active Member
    258
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Hard pass on both accounts.
    Spend your money however you want. I'm sure you'll sell a few more to those who don't know better. I guess grifting isn't illegal after all. :whistle:
    purplePriii likes this.
  12. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    I have been on Prius Chat way too long to be scamming people. Let’s just leave it there. Have a blessed day to you and your Family
    BTW- Your GEN 5 looks great! Keep up the good work!
  13. PhoS
    PhoS Active Member
    258
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Not accusing you of scamming, you're just a middle man. (reseller) I appreciate the service.
    Red bullet, Quantum etc are the real scammers here, just see the malarkey in their marketing. It's pretty entertaining actually.
    Dyjital and RightOnTime like this.
  14. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    I am very sad to say that you are wrong with the Good folks that run Quantum Solenoid.
    During the early development of that Company they used cars from our Shop to test out their solenoids.
    Honestly after that test drive around the shop you can visibly see a smile on their face when they get back!
    Now they are on another level with the Japanese market which says something about their Solenoids.
    I don’t have a horse in the race but just sharing what I have experienced
  15. PhoS
    PhoS Active Member
    258
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Again to each his own. The facts are clear to me, and I'm done here.(y)
  16. wrtboy168
    wrtboy168 Member
    70
    29
    2024 Prius
    found a few yt videos in japanese. a gain of 7hp?
  17. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
  18. Dyjital
    Dyjital Member
    91
    63
    Oregon
    2023 Prius
    XLE AWD-e
    7hp.. where are we going to put all of that HP? Sure wish I had access locally to a dyno. I'd put these to the test.
    WRTBoy168, not directed to you.
    My personal thoughts on this subject....
    Coming from an engineering perspective and previous experience in the forced induction world, if we look at a solenoid and how it operates, for the engine to go WOT, the cam timing can only be adjusted so far forward before you have knock.
    A solenoid that makes a cam move is restricted by detonation. Sure, maybe they trick the ECM into opening it more (earlier) but that's what cam and crank sensors are for. These sensors will tell the ECM exactly where the engine is in its rotation. The engine then takes the throttle position sensor callout and adjusts to a specific amount of fuel at the precise timing to avoid premature detonation or lack of detonation.
    With that said, I cannot see the engineering behind it that would actually allow proper HP gains aside from tricking the ECM and actually opening sooner to advance timing earlier than the stock solenoid. Sure, you may gain a few degrees of timing but that's not much. Butt dyno?
    Correct me if I'm wrong.... but I have two towers in Manhattan I'd like to sell..
    Before I would put this in my car or recommend them in anyones car I'd have to have some real in depth discussions about how this solenoid which is PWM and doesn't rely on two way communications with the ECM can make such gains. If the ECM calls out 1.5* of advanced timing and the solenoid provides 2.75*, this will set a check engine light.
    Nope, not buying it based on my understanding of mechanical systems in vehicles. 100%, not your average Prius driver.
    #18 Dyjital, Mar 6, 2024
    PrimeDan likes this.
  19. ChapmanF
    19,001
    Yeah, kind of a key question. As the only thing this mod changes is the solenoid—there is nothing fancier being done, like spoofing the cam position sensor feedback to the ECM—we should all be able to agree that when the ECM decides to change the intake valve timing from X° to Y°, the cam timing is going to end up right at Y°, no matter which solenoid is installed.
    The only difference that ever has been plausibly claimed for these solenoid mods is that the change from X° to Y° may happen faster. So let's say with the stock solenoid the advance takes 0.25 second to change from X° to Y°, and with the elite solenoid that happens in 0.15 second. At the end of that period the engine is running just the same in both cases; the elite solenoid just got there 0.10 second sooner.
    Giving the maximum possible credit to the claims, let's say that means the engine output during that 0.1 second was 7 HP more. That's not nothing—but usually when you say to someone "this doodad will give you 7 more HP out of your engine", they aren't expecting you to mean "for 0.1 second at a time".
    Of course, the timings above were just made up by me. I don't know what the degrees-per-second slew rate is with the stock solenoid, and I don't know how much faster, if at all, it is with the elite solenoid. Given that changing that slew rate is literally the only effect the changed solenoid can be claimed to have, you might think the promoters would be falling all over themselves to publish what those numbers are. I haven't seen that, though.
    mr_guy_mann, Brian1954 and Dyjital like this.
  20. RightOnTime
    791
    1,660
    183
    Kidnapped in OC, CA
    You are more than welcome to try it out for free…. Just saying
