RED DEAD TRIANGLE WHEN CONNECT ODB2 port
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Fernegri, Aug 7, 2020.
  1. Fernegri
    Fernegri New Member
    HI. I try to connect teh scanner at odb port and the read triangle appears. all the lights start to blink and the car dies. I take it out reset the code the car runs good. but every time that I try to connect apperas again
    CODES
    U0293 - LOST COM WITH HYBRID VCS
    P0A1D - HYBRID POWER TRAIN MODULE
    U0100 - LOST COM WITH ECM/PCM
    U0111 - LOST COM WITH BATTERY ENERGY CONTROL MODULE "A"
    Any idea?
    49,473
    start with the 12v health
    edthefox5 likes this.
  3. ChapmanF
    15,589
    The pins on your OBD scanner ... are they plated? Do they look gold, tin, what?
    This happened to me. when I was plugging in a cable with cheap unplated pins. (Back when it was new, there was never a problem, but later it was the instant I plugged it in, every time.)
    If not, it can also be that certain scan tools probe for what kind of car they are in, and do it in ways that bother a Prius.
  4. Fernegri
    Fernegri New Member
    I have other 2007 prius. I think that could be a bad conncetor inside the ODB plug or the PCM.
  5. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    How many miles are on the vehicle?
    What OBD2 scanner are you using to retrieve the above codes (DTCs) ?? (make, model, app, etc)
